Home > Tdi > TD5 seat box to fit TDI |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
Just the box under the driver's seat, you don't need to cut it as such, just remove the rivets and, IIRC, a couple of spot welds.
You will also need to create a filler panel as the resulting hole is larger than the cover plate. http://www.yorkshireoffroadclub.net/ |
17th Jan 2017 2:39pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2553 |
You'll need to make a plate to fill I'm around the transmission tunnel too as the one that the Td5 seatbox usually attaches to is far wider than the 200Tdi one, so there will be a gap.
17th Jan 2017 7:47pm |
MetalMatt Member Since: 29 Jul 2016 Location: West Yorkshire Posts: 180 |
cheers managed to remove the under storage box lots of drilling out rivits
23rd Jan 2017 5:52pm |
