Home > Technical > Brake line flare Sykes Pickavant
Welkman
Hi,
Having read through various threads I ordered a nice flaring tool that comes with op1 and op2 dyes. Do you know which flare to use on the defender td5 brake lines? I cannot work out how to produce a 'double flare' which I think may be needed as the instructions are terrible !
James
Post #591315 8th Jan 2017 5:51pm
Welkman
Hi,
I think I may have figured it out.....clamp the pipe and use the op1 tool to make a kind of ball and then leave it clamped in place and use the op2 tool (looks like a cone) to produce the flare. I was releasing the pipe in between tools and resetting it which gave seriously ugly results!
Post #591323 8th Jan 2017 6:07pm
Romadog
Post #591327 8th Jan 2017 6:11pm
Devon-Rover
AFAIK the SP is the same as the Snap-on bluepoint so for male unions you use OP1, for female unions you need a double flare so firstly use the OP1 then use the OP2 to create it.
So for instance when you do the 'jumpers' on the calipers, the female unions onto the hose use a double flare and you see when offered up the hose's Male end, the flare sits nicely against it and creates a good seal when the union is done up.
Post #591329 8th Jan 2017 6:14pm
Rickydodah
Double flares are formed by creating the male end and then using the tapered flaring tool to invert the end into a female. There are 2 types of flare nut the SAE type have a straight shoulder and the DIN type a beveled shoulder, be careful to us the correct nut with tthe correct flare type.
Have a look on good old Utube I'm sure there mudt be a video. Thumbs Up I started with nothing and still have most of it left!
Post #591331 8th Jan 2017 6:17pm
Welkman
Look ok?
Post #591407 8th Jan 2017 9:44pm
Nutter
[img]https://www.defender2.net/gallery/albums/userpics/17166/IMG.pdf[/img]
Hello Welkman that looks like a good double flare, that will work o.k.
These are the instructions which came with my tool Very Happy James
Post #591526 9th Jan 2017 12:06pm
Welkman
Thanks for taking the time to do that. I haven't seen any mention of chamfering the edges before, is this common practise on all models? Honestly the directions with the one I have are pathetic!
James
Post #591545 9th Jan 2017 2:06pm
Nutter
[img]https://www.defender2.net/gallery/albums/userpics/17166/23311ins.pdf[/img]
To be honest i don't bevel the pipe to start with, just make sure its cuts square and clean.
Draper flaring tooling instructions also mention chamfering the edges, but can't see how to chamfer outside
of copper brake pipe as is so thin.
James
Post #591565 9th Jan 2017 4:22pm
