Home > Technical > Main Fuse Blowing
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Main Fuse Blowing
Hi Everyone and Merry Christmas to you all,
I'm in need of some help, yesterday morning, first heavy frost, as expected the fuse blew on start up....
So to bring you all up to speed, dual battery system fitted, a few years now, no problems. Replaced 500amp Mega fuse with 300amp ANL.
So early this year when the frosts hit, I was away, Wife goes to start Landy and reports nothing working. As it turns out, lights, dashboard all come on, just a click on ignition. Check main battery fuse and it's blown, swap with spare and all okay. No further problems until 2 months ago and first heavy frost since the new year. Call from Wife as before, swap fuse all okay.
Ordered spares, gone to wrong address and now waiting as post office has them.
Anyway frost yesterday and I went out to start the Landy and turn ignition, let glow plug light go out turn key and try's to start but does not fire up. Turned off ignition, back on for glow plug, re did twice to allow for poor glow plug. Turn key, does not fire, try again and heard fuse blow.
Besides no spare, what is the problem, starter motor? Never a problem otherwise, rain or sun.
Tomorrow I'll use the fuse protecting second battery, Auxiliaries only and replace main battery fuse, hope it warms up. Or I can replace a few cables and fit Land Rover Mega fuse back to keep running, however there is a fault and a 500amp fuse may allow it to fire but is it masking a potentially worse fault......
No faults on the Scangauge, batteries and cables are all fitted plus tested and no signs of a short. All other vehicles fuses are okay. Going to check the voltage at glow plugs, just to rule them out. Will jack up the Landy and check connections at the starter motor.
Any help will be gratefully appreciated, if it's easier PM me and I'm happy to talk it through?
Nobby _______________________________
Puma Defender 90
Post #588199 28th Dec 2016 6:23pm
dorsetsmith
main fuse 400 to 500 amp work with main battery cable from the battery down to starter motor and Alt make shore you have no faults with starter motor or Alt as well as the cabling !
Glow plug are not wired though this fuse
Post #588216 28th Dec 2016 7:02pm
Nobby
Thanks Dorsetsmith, I thought starter motor, didn't think about the alternator. I was happy the glow plugs were a separate circuit, just the nagging issue with only an issue with the extreme cold. Left me rather confused and almost seeking a cold weather reason, hence the glow plugs on my brain.
PM'd you re fuses.
Puma Defender 90
Post #588223 28th Dec 2016 7:16pm
dorsetsmith
Glow plug wired to link 1 100 amp fuse drivers seat box i believe
Post #588235 28th Dec 2016 7:43pm
LR90XS2011
am I missing something ?
the drawing shows the starter motor as 300amps hence every now and again a 300amp fuse will blow, if the factory fitted 400 amp fuse this was for a reason, surly if its cold then the voltage is down a bit and the current goes up a bit so a 300amp fuse protecting a 300 amp load will generally blow when its cold and the load goes up and the voltage down? why not go back to the standard factory 400 amp fuse? If that blows then yes you might have a problem DEFENDER 90 TDCI XS,
Post #588250 28th Dec 2016 8:19pm
Nobby
PM'd you. _______________________________
Puma Defender 90
Post #588266 28th Dec 2016 8:43pm
dorsetsmith
you have PM
Post #588283 28th Dec 2016 9:15pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Nobby,
So let me get this straight, you replaced the 500amp fuse that Land Rover fitted with a 300 amp item and now you are wondering why it blows when you put it under pressure starting on a cold morning ?
Really ?
Post #588312 28th Dec 2016 10:23pm
Nobby
Mo, for clarity, it was after advice and sound at the time, 2+ years with no issues. Maybe as the Landy gets older and parts age, tolerances change. I only found out tonight that the starter motor draws 300amps. With the cold and now things aging it doesn't now work. Lesson learnt and posted here so others may learn. Don't forget even land rover have made a few mods and fitted lower rated fuses, again something I learnt tonight.
When I set out on my merry journey of Puma ownership, I have sometimes followed advice on various items of change for the better, some of which were checked or discussed with others via this forum. However now I've come to a problem which clearly needs addressing and was a little unsure where to go hence my post.
Again others may have gone down the same path, may now taking note and filing it for the time when something similar happens.
This forum is about helping, advising and sharing.
Puma Defender 90
Post #588344 29th Dec 2016 12:09am
dorsetsmith
Post #588376 29th Dec 2016 10:21am
Mo Murphy
Interesting nobby, is there a thread you could link to where the 300 amp fuse change is recommended, I should like to try and understand the reasoning behind the recommendation that was made to you ?
Post #588446 29th Dec 2016 5:32pm
Nobby
PM'd you _______________________________
Puma Defender 90
Post #588482 29th Dec 2016 6:54pm
LR90XS2011
hope it is sorted mate nothing more annoying than a recurring defect DEFENDER 90 TDCI XS,
Post #588515 29th Dec 2016 8:09pm
Nobby
Hi LR90XS2011,
All is pretty fine now Thumbs Up located a mega fuse holder in Swindon, fitted it this morning. Used the original 500amp mega fuse and it started as well as ever. In my case instantly Very Happy I've removed the 500 and waiting on the Postie to deliver a 400amp fuse from dorsetsmith. Bow down Bow down
I may just be the unlucky one whose 300amp fuses and a vehicle getting older couldn't cope. Hopefully anyone else who went this way has an early heads up on potential problems or are having a similar issue now and have an answer.
It is the way of the defender, live with it, tinker with it but always learning from it.
Puma Defender 90
Post #588532 29th Dec 2016 8:49pm
