Home > My Defender > Not my defender but my trailer |
19th Dec 2016 6:25pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 644 |
Thanks for the suggestion but looks a little pricey for the qty I need. Also would need a lot of fixings.
20th Dec 2016 2:11pm |
I have done a few for friends and have used either Phenolic Resin Plywood 18 or 22 mm or Stokbord .
What ever the flooring you use I would put the lighting cables under the chassis members to prevent damage. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
20th Dec 2016 3:01pm |
Phenolic board would be best. Aren't you going to paint the inside of the wood? Ray
20th Dec 2016 4:48pm |
Thanks - I think Phenolic board is my preferred solution at the moment.
It isn't that clear from the photos but the cables are all under the chassis members apart from where they go over the axles. The axles are slightly lower than the floor level and will have a packer piece between them and the floor so the cables won't rub. The wood sides are all pressure treated timber - The outside paint is purely for cosmetics. I have never painted the inside on the rationale that it will end up filled with rubbish and the paint will easily be damaged! |
20th Dec 2016 4:50pm |
Stokbord/stockboard/... - it's a recycled plastic that's extremely tough and hardwearing. Half our farm is made of it
It will droop a bit if it's unsupported and it gets warm, but it looks like you've got plenty of support there. We've used it for walls, roofs, mounting our main electrical DBs, floors (similar applications to what you need), guards for things... loads of stuff. It's easy to work with, doesn't rot, it's great. |
20th Dec 2016 6:17pm |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
Looks nice and has a classic feel, like the colour too. Ideal excuse to add a Series next to Defender.
Regards, Joris |
20th Dec 2016 8:36pm |
