Home > Td5 > Bulkhead swap |
If you could take a pic or two when you get the old bulkhead back it would be much appreciated. I will be replacing my windscreen surround in the next few months so a couple of pics would be a good heads up Ray
19th Oct 2016 10:02pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5748 |
Saw the 110 to day, Wings on and aligned, bonnet, grill all back on. Windscreen frame back in place - just needs bolting down and glass going in.
Hopefully back with me tomorrow. @Mk1Collector - do these pics help? Click image to enlarge Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
21st Oct 2016 6:54pm |
Absolutely perfect thanks gives me a good idea of what I'll be up against when swapping mine out. Ray
21st Oct 2016 8:55pm |
No worries, As you can see a bit of rust. Was offered £100 for it...not sure, I think it might be worth more. 1999 Defender TD5 110
21st Oct 2016 9:44pm |
110 is back!
Just two issues. Radio not working and washer jet on drivers side not working. Radio fixed but the washer jet, I think the pipe has come off and is leaking.... Apart from that all good. Plus I got to drive a TD5 110 with a slick shift fitted = deffo on my list of mods. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
22nd Oct 2016 7:06pm |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 341 |
Mk1collector, this is my Defender 2001. I had the frame out and was thinking these might help you:
Apologies for the upside/sideways images. I blame Photobucket! Click image to enlarge[/URL] [/img] Click image to enlarge[/URL] [/img][URL=] Click image to enlarge[/URL] Click image to enlarge[/URL] [/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
25th Oct 2016 7:43pm |
Excellent thanks just a quick question, did you unbolt the roof any further back or just around the screen surround? Ray
25th Oct 2016 11:27pm |
I'm changing the thick black rubber/foam strips at the back running under the tub so I unbolted or loosened all of the rear ones as well. I think you need to do this anyway to allow clearance for the screen/frame to fall into the cab slightly so it can be lifted off the locators/pegs. Mike
26th Oct 2016 9:05am |
I think when mine was done, at least the bolts for the front of the roof got removed which I think gives enough movement to remove with out undoing all. 1999 Defender TD5 110
26th Oct 2016 9:12am |
Good to know for next time. Mike
26th Oct 2016 9:19am |
Thanks chaps I just need to line up a soda blaster to clean my replacement frame now as the soda blaster I had lined up has decided he only does large onsite jobs now I think it will be next year when I get the job done now. Ray
26th Oct 2016 11:32am |
