Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 36 of 81 <123 ... 353637 ... 798081>
JOW240725
Looks much better. Thumbs Up Did you see the tests BAS did on the KBX and snorkels? James
Instagram @suffolk_rovers
Post #568511 3rd Oct 2016 10:22pm
mk1collector
Cheers chaps Thumbs Up I'm going to try and get it bolted on this week but I'm a bit busy trying to help my sister out at the moment doing some work in her garden Rolling Eyes Ray
My build thread
Post #568550 4th Oct 2016 9:52am
mk1collector
I'd heard they had done some tests with snorkels but didn't know they had tested kbx vents too. Did they make a big difference in performance? And do you have a link? Ray
My build thread
Post #568551 4th Oct 2016 9:53am
JOW240725
The effect of the KBX is only slight compared to a RAI, but interesting reading. I copy below the results for interest (I can only find them on FB).
Quote from the BAS Remaps FB page:-
"So that is that then.. KBX and snorkels ARE restrictive and cause more vacuum draw on the crank case which is the nearest point to the turbo inlet and without a shadow of doubt can contribute towards oil in the compressor housing of the turbo and a difference in power to a non snorkel car.
The KBX is not so bad it seems but does cause more restriction than the OEM wing vent and also causes air turbulence in the intake system which is harder to measure as a problem than the flow and pressures are.
In the case of the snorkel and the supposed "Ram Effect" it seems that using a nominal pipe size of 65mm which is the most restrictive part of the air intake system the post separator area @ 1bar pressure and @ 20C temp, flowing 250CFM you would need to be going over 68MPH to get a balance of air speed and forward flow before any gains from Ram Effect start to give you anything extra or contribute towards recovering air flow lost from the fitting of the snorkel in the first place.
Increasing the internal pipework size to 80mm reduces the needed road speed to 48MPH and increasing further to 100M reduces it again to 29MPH.
 James
Post #568564 4th Oct 2016 11:28am
mk1collector
Interesting reading, thanks for posting it up Thumbs Up hopefully it shouldn't affect mine too much as I've done the airbox mod too so it might cancel out fitting the kbx vent. Ray
My build thread
Post #568567 4th Oct 2016 11:45am
JOW240725
I'm sure you're better off. The figures suggest the 'vanes' in the air box are far more restricting than the KBX vent.
When you see the KBX vent next to the OEM vent it's difficult to see how it can be more restricting as it looks to have a bigger free area, but maybe it's more down to the air turbulence? Confused
I looked at modifying the airbox and installing a larger diameter inlet hose, but with ABS in the 2.2 it's all very tight for room! James
Post #568568 4th Oct 2016 11:52am
mk1collector
I was thinking of putting a larger diameter pipe in at some point as I don't have abs, another thing to add to my growing list of jobs Rolling with laughter Ray
My build thread
Post #568612 4th Oct 2016 3:44pm
JOW240725
Haha, exactly! I'm guessing BAS, having done the research, will be coming up with a range of 'free flowing' air intakes, vents, hose and modified box... James
Post #568614 4th Oct 2016 3:47pm
mk1collector
I hope not or I'd "NEED" to buy it Rolling with laughter Ray
My build thread
Post #568617 4th Oct 2016 3:57pm
mk1collector
Rubbed the outer bit of the vent back down and re primered because in certain lights you could see a ghost kbx logo Big Cry I'll try and repaint it this weekend if I get time. I should really be spending my money and time on the other 5 million jobs rather than a poncey painted vent Rolling with laughter Ray
My build thread
Post #570186 11th Oct 2016 11:02pm
Grenadier
That is interesting. I have a KBX intake and just last week the engine management light came on and when plugged in by a local garage it was the airflow sensor reading. He turned it off and we checked the ports were clear and he said drive I think for a few days and see if it returns. It did. However interestingly it did so just before my long run to Bordeaux (6hrs motorway driving) and it turned itself off, I assume because it had a clean, regular flow of air for a prolonged period? Maybe the KBX is creating the problem? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #570209 12th Oct 2016 8:18am
mk1collector
Defender needs a good wash but I finally got a dry day to put the vent on.
 Ray
My build thread
Post #571057 15th Oct 2016 5:35pm
mk1collector
Just won this on eBay for £32 Mr. Green decent saving over the normal price of about £160 and it looks almost brand new Mr. Green
I can finally tidy up all my rubbish I carry around now. Rolling with laughter Ray
My build thread
Post #583519 8th Dec 2016 6:46pm
prezzy
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
You lucky Censored !
Been after one of those myself. Thumbs Up
Post #583522 8th Dec 2016 6:56pm
mk1collector
Yeah, I've been looking at them for a while but been putting it off because of the price (lots more priority jobs) but when this came along I snapped it up. The chap had it on for £60 buy it now but I forgot about it before the auction ended then he relisted at 99p start so I bid straight away and only one other person bid against me Mr. Green Ray
My build thread
Post #583524 8th Dec 2016 7:08pm
