Home > Td5 > Trailer repeater indicator problem
drinkdrinkdrop
Hi
Picked up a used TD5 and whenever I indicate the trailer repeater will also flash despite no trailer being connected, a previous owner replaced all the lights but the headlights with LED if that makes any difference. Any advice appreciated
Post #565051 19th Sep 2016 12:19pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Does it flash all the time or just once when you start indicating ?
If the latter then that's normal, it's done to prove that the dashboard indicator works (or at least that's the official line...) http://www.yorkshireoffroadclub.net/
Post #565053 19th Sep 2016 12:22pm
drinkdrinkdrop
It does exactly what I do with the indicator so if I indicate it flashes for as long as I'm indicating and is off when not indicating
Post #565056 19th Sep 2016 12:24pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Mine does this as well. It is to do with the replacement relay for the indicators. The early ones could not control the flashing of the trailer tell tale independantly. I believe that RDX and Wipac now do relays that work as they should once dialled in correctly. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #565059 19th Sep 2016 12:44pm
davew
It could be down to any number of things but I'd start by changing the flasher unit - you may find that there's a none standard one fitted to cope with the LED indicators. The quality of these is "variable" ! http://www.yorkshireoffroadclub.net/
Post #565060 19th Sep 2016 12:44pm
300TDi CSW Phil
Mine is a wipac one which came with the kit. IF I have any trouble I'll change it but to be honest to date I haven't had an issue. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #565061 19th Sep 2016 12:53pm
drinkdrinkdrop
I'll take a look at the relay, thanks alot guys
Post #565063 19th Sep 2016 1:04pm
TomekW
Poland 2003 Defender 110 Td5 SW Bonatti Grey
this shall cure your problem
http://www.paddockspares.com/adjustable-flasher-relay.html 2021 Defender 90 D250
1998 TUL
1997 TUM FFR
2003 Defender 110SW Td5
1985 ExMOD 110 ST 3.9 V8
1971 Series IIa Lightweight
Post #565786 22nd Sep 2016 2:41pm
drinkdrinkdrop
Put in an RDX relay and all now working, thanks for your help Thumbs Up
Post #565787 22nd Sep 2016 2:45pm
