Home > Td5 > Trailer repeater indicator problem |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
Does it flash all the time or just once when you start indicating ?
If the latter then that's normal, it's done to prove that the dashboard indicator works (or at least that's the official line...) http://www.yorkshireoffroadclub.net/ |
19th Sep 2016 12:22pm |
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 |
It does exactly what I do with the indicator so if I indicate it flashes for as long as I'm indicating and is off when not indicating
19th Sep 2016 12:24pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 746 |
Mine does this as well. It is to do with the replacement relay for the indicators. The early ones could not control the flashing of the trailer tell tale independantly. I believe that RDX and Wipac now do relays that work as they should once dialled in correctly. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
19th Sep 2016 12:44pm |
It could be down to any number of things but I'd start by changing the flasher unit - you may find that there's a none standard one fitted to cope with the LED indicators. The quality of these is "variable" ! http://www.yorkshireoffroadclub.net/
Mine is a wipac one which came with the kit. IF I have any trouble I'll change it but to be honest to date I haven't had an issue. 1995 300 Tdi Epsom Green - It's a keeper.
19th Sep 2016 12:53pm |
I'll take a look at the relay, thanks alot guys
19th Sep 2016 1:04pm |
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 192 |
this shall cure your problem
http://www.paddockspares.com/adjustable-flasher-relay.html 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
22nd Sep 2016 2:41pm |
Put in an RDX relay and all now working, thanks for your help
22nd Sep 2016 2:45pm |
