Home > Wheels & Tyres > Fitting ZU alloy onto Mantec style Spare Wheel Carrier |
Thor Member Since: 17 Dec 2011 Location: Didcot Posts: 446 |
I had the same problem switching from Twisted alloys back to boosts. I went with a spacer to push the wheel out a bit. Strong people are harder to kill and generally more useful!
3rd Sep 2016 11:31am |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
I had the same issue, there should be some large spacer nuts that fit between the back door and the wheel rim, obviously a set of 3, then you can adjust the distance from the back door to stop it rubbing etc depending on the tyre width. They are fairly loose until the wheel is bolted on.
Like these..... http://www.xplorlandrover.com/DEFENDER-SPA...ER-GENUINE |
3rd Sep 2016 11:58am |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
I use steel wheel nuts on the inside of the wheel and alloy wheel nuts on the outside. I set the inside 8nes so the tyre clears the door and then use lock the alloy one on so it sandwiches the wheel between the two bolts 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
3rd Sep 2016 2:34pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 746 |
Thanks guys, I have worked out a solution using the outer plate of my "on the door wheel carrier" cut down accordingly to support the back of the alloy wheel against the stop nuts. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
3rd Sep 2016 3:33pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
I just screwed a normal nut onto each stud and then slid a large washer onto each one for the wheel to press up against. Screw the nuts in or out to adjust the space between the tyre and the door. ONE LIFE, GET IT!
3rd Sep 2016 3:46pm |
So here it is the backing plate to take the spare wheel
Click image to enlarge Complete with vinyl covered cable bike lock to secure wheel to the carrier. Handily the bracket bolted around the tube of the wheel carrier so it wont bounce around. Wheel on and locked up Click image to enlarge Now has the spare wheel cover on as well. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
4th Sep 2016 2:56pm |
