Home > Puma (Tdci) > mysterious noise |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4522 |
Yesterday I noticed vibrating noise comming from the drivers side of the engine.It only appeared when comming off the accelerater.Today in daylight and with the help of Mrs. Spudfan I found the cause.It was a loose bracket holding the heatshield in place over the turbo.It just needes tightened.Thought I would post it incase someone else experienced it. 1982 88" 2.25 diesel
16th Dec 2008 8:12pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Well diagnosed. Was it a buzzing noise or a rattle (I appreciate that's a slightly subjective question). |
16th Dec 2008 11:57pm |
Sounded like a roughness when easing off the accelerator.Was very loud when I pulled the bonnet and pushed then released the pedal by hand.Today when the mrs. worked the pedal I could see a shudder in the heatshield as she came off the revs.I did not know if it was the heatshield or the turbo.All the bolts on the heatshield seemed tight.Then I noticed a bracket that is bolted to the engine just behind the pulleys was vibrating so I tightened the bolt holding it and the problem was solved.Sounds complicated but it is the only way I can describe it.Anyway it was very easily cured once I found the problem.I am glad I did not go to a garage with it but it was bothering me last night.Eduardo could probably put up a diagram of the turbo and heatshield and the bracket would be easily seen then.He is normally very good with those things. 1982 88" 2.25 diesel
17th Dec 2008 12:12am |
Genius. Thanks. Makes complete sense.
17th Dec 2008 12:15am |
If only everything was as easily solved! 1982 88" 2.25 diesel
17th Dec 2008 12:18am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Thanks spud,and yes if only. 2.4 90 XS
17th Dec 2008 9:43am |
