Home > In Car Electronics > Headlights Suddenly Turn On And Light Switch Off
HardCharger
2011 Defender 110 Puma 2.4 SW Stornoway Grey
Hi All!
Just encountered this peculiarity two days ago. Every now and then, once parking, turning off the switch to turn off the headlights, they go out momentarily but will come on again for a few minutes then turn themselves off. The position lights are obviously off at this point and it was very alarming at first.
Question now is, any idea what causes this so I can deal with it? The sparky that worked with it installed headlight relays a few days before the Land Reizinger kit then installed the kit on top if that. Been trouble free since installation a few weeks ago up until two days ago.
I can't deal with it right now but have an appointment with the sparky next week. So any suggestions will help so we can narrow things down when we meet.
Many thanks in advance! It's really never over in a Rover...
Post #555205 11th Aug 2016 5:36am
Have you upgraded your h4 lamps to a higher wattage? Sounds like your switch has partially melted
Post #555206 11th Aug 2016 5:47am
bear100
Most likely the switch has melted, do a search on this site loads of info.
There are a few kits available to help with the issue, basically all the voltage to the lights goes through three light switch.
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #555310 11th Aug 2016 1:13pm
HardCharger
Hi All!
Still using standard wattage lamps, albeit they be Osram Nightbreaker Ultras.
I already have the Land Reizinger kit installed plus a redundant relays installed as well.
New switch was installed a few months back and with the wiring kits, I was presuming that this will no longer be a problem so what gives?
Since I'll have the steering cowls removed to check the ignition switch to eliminate this as a culprit for another issue I'm encountering, I'll let the sparky check the switch as well then.
If anyone else has any ideas, please do chime in. I see the sparky next week so it would be nice to hand him a list of possibilities to check. That, plus the earth cheat sheet for him to ponder over as well.
Post #555577 12th Aug 2016 3:13pm
Eduardo
Check the relays of the new installation.
Happens sometimes in wet climates that the relays goes weird due water ingress.
Cheers and good luck Eduardo
Post #555579 12th Aug 2016 3:16pm
bear100
in that case swap the relay to test Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #555638 12th Aug 2016 8:33pm
HardCharger
Thanks for the additional tip, Eduardo and bear100! Will do! Thumbs Up
Post #556107 15th Aug 2016 5:03am
