Home > In Car Electronics > Split charge Q's |
Hi bear
Have a chat with Tim at the mobile centre, he sells complete kits with batteries, cables, connectors etc I fitted one in 2 evenings for a fellow defender2.net member, he's now in on vacation testing and enjoying it You need a few tools and electrical awareness but it's really not rocket science Pm me if you want any more info |
2nd Aug 2016 8:12pm |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 |
Yellow Tops get a good name but can be expensive. I bought one of these below for my Discovery 3's set up and these also get a good write up on the Disco3 forum. I'll be using mine for my fridge, lights and charging iPads etc
I used the Tmax split charge system but now have an uprated relay https://www.tayna.co.uk/EXV70-Enduroline-L...P8727.html This is the relay I replaced it with but you can buy full kits http://www.12voltplanet.co.uk/12v-300a-hig...relay.html 2007 Defender Puma Tonga Green 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
2nd Aug 2016 8:15pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
I spoke to Tim at Mobile Centre when I was looking at options. Got some really good advice and based on what I needed Tim put together a kit for me with the 7610 relay:
https://www.mobilecentre.co.uk/index.php?m...4e4ee6ef4a Once I'd worked out where to borrow some big crimping pliers from it took about a day to fit with no issues as the kit was very comprehensive. Would probably be quicker at fitting this a second time around as a lot of time went into working out where to fit everything so that it was accessible going forwards. Keith Keith |
3rd Aug 2016 7:42am |
Are about £20 ... |
3rd Aug 2016 7:50am |
I ended up borrowing a set from a colleague like these:
https://www.amazon.co.uk/dp/B015ZIA146?psc=1 Made it easy to do the 35mm cables Keith |
3rd Aug 2016 7:56am |
Click image to enlarge Is what I use to monitor the batteries |
3rd Aug 2016 5:50pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1868 |
bp man now that looks good! i have just purchased a double din, so the relocation panel has a spare circle hole which hopefully will fit the gauge!! 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
3rd Aug 2016 5:56pm |
eBay delivered from oz
3rd Aug 2016 7:10pm |
