Home > Maintenance & Modifications > LED light sets |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Thanks !
Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
14th Jun 2016 6:36pm |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 |
CarMan - I know the thread is old, but am wondering what you ended up with?
Like you, I am finding the website ads quite vague, and am having a hard time finding the kit that fits my needs. |
14th Jan 2018 7:24pm |
http://www.island-4x4.co.uk/light-defender...28044.html
That gives you most things, then you add the fog and reverse: http://www.island-4x4.co.uk/light-wipac-xf...27366.html http://www.island-4x4.co.uk/reverse-light-...27365.html and the side indicators and centre brake light: http://www.4x4overlander.com/product/led-s...-defender/ http://www.4x4overlander.com/product/defender-led-brake-light/ The Wipac relay is sensitive enough to notice if you have a trailer with LED indicators providing you set it up carefully. If you don't set it up carefully then it won't. With the engine running (that's important) put the turn signal on and gradually tweak the control until the trailer warning just goes out. If you do it using the hazard lights or with the engine off then you'll set it to the wrong place and it won't detect LED trailer lights properly. |
14th Jan 2018 7:57pm |
Nadine90 Member Since: 07 Jan 2018 Location: CAERPHILLY Posts: 49 |
You tried defenderupgrades ?
14th Jan 2018 8:31pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Isn’t that your company Nadine? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
14th Jan 2018 8:39pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1779 |
I ended up with a mix, though coincidentally as posted earlier today I am keen to find a noisier indicator relay. I wanted to keep the traditional look with a modern (LED) twist so finally ended up with: WIPAC side lights, brake, fog, reverse lights & RDX dark side repeaters Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
14th Jan 2018 8:54pm |
@Cupboard - thanks for the links, and particularly for the info regarding the trailer - I had no idea this could be an issue! I'm assuming there is a control on the relay that needs to be adjusted as you describe?
@Nadine - i did look at the site you mentioned, but didn't have the combination I am after. As Sulisuli mentioned; if its your site, in the interest of transparency and good form, you should mention it. @Carman - thanks for the info. Looks like I will follow the same route, getting what I need separately. |
14th Jan 2018 9:35pm |
