Home > Maintenance & Modifications > LED light sets |
Ridgeback defender Member Since: 11 Mar 2013 Location: North West Posts: 85 |
Looking to purchase LED lights for a 2010, 90 H/T. What do you recommend ?
21st May 2016 9:25pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19560 |
"Rdx led side, brake, fog, reverse and indicator lights.
Side indicators from 4x4 overlander " Exactly the same as me. |
21st May 2016 10:06pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
I forgot wipac number plate light too 2004 TD5 Defender 90 xs station wagon
21st May 2016 10:13pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6479 |
95mm NAS/SVX type. 2 and a quarter times the lit area of the standard (tiny) lamp 1988 90 Td5 NAS soft top
2015 D90 XS SW |
21st May 2016 10:16pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10491 |
Me to as Johnszs 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
21st May 2016 10:27pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Click image to enlarge NAS lights with LED bulbs. MUCH better than any LED offering from any manufacturer |
21st May 2016 10:52pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2724 |
What do people do about LED indicators?
I can't afford to lose trailer light indicator or any faffing around if I attach a trailer. Do the aftermarket relays handle it well? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
21st May 2016 11:20pm |
Yes, they are adjustable.
Only issue you'd have is with LED lit trailers. If that was the case you'd need resistors the trailer OR a buzzer instead. My trailer is incandescent lit so keep the light with my RDX kit. I may go LED on my trailer one day but that would be an annoyance. It'd work, no problem but the legality of light or buzzer would not be there, which is very annoying! |
21st May 2016 11:27pm |
Yeah that seems to be my understanding.. However RDX advertise a relay which can supposedly deal with trailers and also a mixture of LED/bulb lights on the car.
Very tempting. It's included in this kit which seems good value: https://www.ebay.co.uk/itm/390534410803 Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
21st May 2016 11:35pm |
That is good value, I spent a lot more than that for the same set.
Don't get my wrong physically the lighting on vehicle abd trailer will work perfectly regardless of LED's or incandescent standard bulbs. The relay also allows you to adjust the dash trailer light too. The one and only issue is if you have an LED lit trailer the dash trailer light then won't work. The trailer lights will fine but with no indicator warning buzzer or dash trailer light on when towing is illegal. It's not an issue to me as my trailer is incandescent lit as standard. There's no real workaround to keep the dash light around this on if yiu had an LED lit trailer other than resistors on the trailer indicators or a buzzer fitted in vehicle instead. Overall, an excellent solution. |
22nd May 2016 12:51am |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1777 |
So, are the Wipac and RDX sets different? Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
12th Jun 2016 7:04pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
12th Jun 2016 8:28pm |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
http://www.bowerspartsonline.co.uk/vehicle...t-rdxwipac |
14th Jun 2016 3:01pm |
They are slightly different in reflector design and light pattern, however, you'd barely notice.
14th Jun 2016 3:13pm |
