Home > Td5 > TD5 centre console and dash binnacle tabs. |
Can't see the pic. Ray
25th Jul 2016 11:00pm |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 249 |
Click image to enlarge Thanks, try again! |
25th Jul 2016 11:31pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2269 |
Probably easiest to get a replacement, check to see how much it costs new. You could cable tie it in place by drilling a hole in the remains of each mounting, plus another in the main dash where the mounting is, then put a cable tie through both holes.
26th Jul 2016 7:55am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
You can buy them new, but they are quite expensive, and second hand they seem very sought after - so I'd try gluing new tabs on first. I've not done it myself, but abs plastic is supposed to be quite easy to work with.
Having said all that - if you do buy a replacement I'd buy this broken one, which might offset some of your costs? |
26th Jul 2016 8:11am |
Just use a big washer under each screw to clamp it down. It's not and area that should get much pulling about. Ray
26th Jul 2016 12:23pm |
Thanks All.
Replacements appear rare, and had a quick look on-line last night- £180 from a supplier! I'll try the washer route and see how it hangs on! Cheers, Robin |
26th Jul 2016 12:40pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
I've successfully repaired a couple of very similar broken tabs on the instrument (Clocks) binnacle on my 90.
I found a bit of a broken casing from an old scrapped TV of a similar thickness and type of plastic and fashioned some replacement tabs to fit in place of the broken off bits, then glued them in place with PVC pipe adhesive, I clamped them in place while the glue set and just tidied up around the edges and now they're as good as new. |
26th Jul 2016 12:55pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
If you know anyone with a 3D printer they could print some replacement tabs for you with a suitable way to attach them to the existing surround. http://www.yorkshireoffroadclub.net/
26th Jul 2016 1:02pm |
If I remember correctly the tabs are only like a 2 prong fork anyway so it's just the screw clamping down that holds the console in place so washers will be fine. Ray
26th Jul 2016 3:59pm |
