Home > Technical > Oil Service indicator help |
It is there for a reason and based on condition not time. Nevertheless if you wish to circumvent this warning and reset it on page two of this thread I posted a couple of ways of resetting it which worked for some. Timing is of the essence so take note.
http://www.defender2.net/forum/topic25462....ight+reset If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Jul 2016 2:14pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
Snap. Mine is same age and a couple of 100 extra miles and has just come on as well. Only difference is - mine has already had an oil/filter change done at approx. 3k. |
24th Jul 2016 2:25pm |
toby9946 Member Since: 23 Sep 2015 Location: Hampshire/London Posts: 96 |
Thanks K9F
Maybe the DPF wants to regen so will take it for a bit of a blast later. Failing that will try the reset method as oil level is spot on and seems very clean. -2015 Defender 90 XS Landmark- |
24th Jul 2016 2:34pm |
Okay so blast back to London didn't fix it, but reset the indicator with the brake and accelerator pedal method.
Will now do an oil change for peace of mind incase it has indeed got too much diesel in it. Any recommendations for the weird 934B spec oil?! Also will the fact the oil service light came on be logged in the ECU now its been reset? Cheers! -2015 Defender 90 XS Landmark- |
24th Jul 2016 8:56pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4502 |
Site sponsor
http://www.advancedfactors.co.uk/06-servic...-210-c.asp 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
28th Jul 2016 11:17am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6486 |
Oils list: http://www.defender2.net/forum/topic34176.html
Bear in mind you will now not get a warning when it is due its service. The Fuchs oil in C2 spec that Advanced Factors are listing does not appear to have the Ford 934B approval. It should be C1 spec. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
28th Jul 2016 11:45am |
Thanks Martin I had just noticed that it's the wrong spec too!
Actually ordered some Millers C1 from Opie. It's due it's service end of September so will have remember to get it done then. -2015 Defender 90 XS Landmark- |
28th Jul 2016 11:50am |
I wouldn't bother going to the added expense of swapping the oil again in September. Keep the receipt and just let the dealership know it's been done. Change it next time you get the warning. If you go through life with your head in the sand....all people will see is an ar5e!!
28th Jul 2016 12:14pm |
