Home > Td5 > Drain tubes, pipes etc on 2001 TD5 Hard top |
vent tube from axial front and rear gear box and transfer box, part wading kit fitted at LR up to the back of engine bloke
23rd Jun 2016 7:49am |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 341 |
I've seen mention about gutter and heater drains. Should I be looking for these as well, if so could you point me in the right direction?
23rd Jun 2016 7:16pm |
1, gutter run, front to back on side of the roof both side 2, heater drains, the on only thing i can think of is air inlet duct to the heater fan has drain remove the plastic grill from wing top and you will see duct and drain hole in it ( can get block ) ! Click image to enlarge Last edited by dorsetsmith on 24th Jun 2016 7:14am. Edited 1 time in total |
23rd Jun 2016 7:42pm |
Many thanks, I'll check it out
23rd Jun 2016 9:33pm |
