Home > My Defender > My first Landrover and plans for it |
Dtfrith Member Since: 01 Nov 2014 Location: Manchester Posts: 76 |
I am going to order the wolf wheels, just need to sort tyres. Would 265/75r16 work on the 6.5 wide rims? Interested to know the answer to above as well.
25th May 2016 7:18am |
FWIW (not much?) I had a 235/85 fitted to a LR genuine wolf wheel today and rolling it out and heaving on to the spare carrier gives me a weee bit of insight to this >> I really cant see another 30mm being an issue... Solved the bowel problem, working on the consonants...
25th May 2016 7:23am |
If you look at the specs that manufacturers provide for their tyres, the widest you can fit on a 6.5" rim is 255/85.
265/75 asks for a 7". Not to say it's not possible, people put 235s on the 5.5 steel wheels and that's out of spec too. |
25th May 2016 9:10am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16881 |
On Puma-engined Defenders, aircon was standard only on XS models. On all other models (County and below) a/c was a build-time (factory-fitted) option.
Many, many Pumas do not have aircon. |
25th May 2016 9:58am |
After a bit more reading and shopping I now have a list of bits to sell / swap. Eg, I would like to exchange the raised suspension for standard kit. Am I aloud to put up swaps in the sale area??
30th May 2016 9:07pm |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 489 |
Just to add, I'm running standard length studs on my wolfs (wolves??). Regards to torque, I honestly have no idea, I did them up fairly tight, had no troubles after a couple of hundred miles . I did put a load of copper grease on the nuts and studs in the hope they'll come off easy when necessary. Also to add: As mentioned in other threads, the shorter studs mean the ends are protected by the nuts so the thread doesn't get damaged. Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
30th May 2016 9:24pm |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
From memory on clean dry threads it's something like 110Nm for steels and 130Nm for alloys. Despite all the b*ll*cks I still copper slip my hub mating faces and the threads and yet have never ever had one come loose or even begin to work. |
30th May 2016 9:41pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
This wouldn't be the same lany I walked past and had a good look around today parked up just down the road from a chippy? It does look very nice so far
On the topic of Wolf rims they are to be torqued to 170nm on the Wolf fleet and also the old 90/110 fleet that never had the longer studs fitted, it looked wrong to see a nut with visible threads as the stud did not even come flush. There was as part of the retro fit a small plaque that was riveted into the cab "Wolf rims fitted torque to 170nm" 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
30th May 2016 10:01pm |
K.M Member Since: 28 Apr 2016 Location: Salisbury Posts: 300 |
You need a few more posts first think it's 25 or so... |
30th May 2016 10:41pm |
Yea that's me, I live opposit where it is parked, give a toot if it's out there the the next time your visiting the chippy 👍🏼 |
31st May 2016 6:23pm |
Ah right I will have to wait for a bit then, thank you. |
31st May 2016 6:32pm |
Click image to enlarge Click image to enlarge Can anyone tell me what this is? Can anyone tell me what this is?? |
2nd Jun 2016 10:03am |
It's the heater outlets I believe. Matt.
2nd Jun 2016 10:07am |
Yes, the knee warmers. If you fiddle around with the heater settings some air should eventually trickle out of them.
2nd Jun 2016 12:15pm |
