Home > My Defender > My first Landrover and plans for it |
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 |
Hiya,
Well the full width load mat is a genuine LR one, fitted one when we got our HT about 130 quid from the dealer. Wheels Genuine LR HD steels somewhere around 60 quid each plus tyres, theres a recent thread one here regarding steel wheels if I can find it. 3 Landrovers |
23rd May 2016 9:38pm |
This thread? http://www.defender2.net/forum/topic31672.html
The wheels in the first Defender you said you liked were the standard duty steel wheels with Michelin Latitude 7.50 tyres. The wheels in the second one are the HD Wolf wheels with 235 Goodyear MTRs. |
23rd May 2016 10:32pm |
Dtfrith Member Since: 01 Nov 2014 Location: Manchester Posts: 76 |
Great! Thank you guys. I will let you know how I get on with the appraisal.
24th May 2016 10:06am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
The existing grille and headlight surrounds you have are KBX and you can sell those easily and for good money.
The look you are going for is standard Land Rover grille and headlight surrounds, cheap as chips and possibly even free if you put up a wanted advert |
24th May 2016 10:11am |
My 110 came with the KBX set and I too swapped it for the factory spec.
The net total to and fro meant that $$ came my way - good luck to you! Funny, I want wolf wheels on mine too, but the cost in shipping is painful down this way. I did get one, which is now my spare, the studs will allow enough thread to get you moving, but I'm not convinced it's the best thing for a permanent set up, so the studs (x20) add to the cost (for me at least). Not sure if you wanted to, but I wouldn't remove the tread plate (your goal image doesn't have any), you'll be left with holes to plug... Also, small chance you're not aware, but your intended look may be part informed by the puma 'bump' in the hood, IMO it's a total affectation. The vehicle in the pic doesn't have aircon, which as far as I'm aware means it's not a puma spec itself (?), I'd stay with yours personally, quite fetching, but more to the point: model accurate (once you remove the 'defender' hood letters and go back to the original decal) >>edit, also doesn't have the vents, so yeah ok it appears pumas did come without air con (??) Solved the bowel problem, working on the consonants... |
24th May 2016 10:38am |
STC4629 LR rubber mats part number
24th May 2016 10:58am |
I will get some pictures up and see if anyone is interested. |
24th May 2016 7:45pm |
Thank you. I have the mat on the main floor area just not up the sides, I'm guessing it is supposed to come as one? |
24th May 2016 7:46pm |
yes but you can sale the present one
24th May 2016 7:58pm |
I am going to try and off set the cost of the new wheels and tyres by selling the current ones, any ideas on how much I should be asking for??
Click image to enlarge |
24th May 2016 8:04pm |
Great stuff. |
24th May 2016 8:08pm |
Longer studs do exist, but Land Rover and almost everyone using Wolf wheels use the short studs. You bought a car from the factory with Wolf wheels, short studs.
24th May 2016 10:31pm |
To keep on both sides of the discussion you could buy 4 studs and use one per wheel as a 'safety' Solved the bowel problem, working on the consonants...
24th May 2016 10:43pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1633 |
No need for longer studs with Wolf wheels... YOLO... You Only Live Once...
24th May 2016 10:51pm |
