Home > My Defender > 300tdi 110 Project.
Page 4 of 6 <123456>
L110CDL
Good days work i would say Nidge Thumbs Up Cant beat a nice new shinny chassis Whistle 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #531840 15th May 2016 9:34pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Engine and gearbox together again, and front cab back on , just to plumb in the pipe work, fit the tank and hopefully engine will be good to go
Some Shiny new brackets from YRM , their stuff is top class Thumbs Up
Post #532530 17th May 2016 10:45pm
L110CDL
Progression is really moving quick Nidge, looking good Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #532533 17th May 2016 10:49pm
Nidge
Starting to look like a Land Rover again, most of the body work is now in place, loosely bolted together, next job is to try and line up all the panels nice and straight.
Rear tub was a bitch to fit, it didn't help that there were discrepancies in the manufacture of the chassis and some of the brackets won't fit. Rolling Eyes
Installed a new steel fuel tank and gave it a couple of coats of Dinitrol before fitting it to the chassis, only temp in as I hadn't ordered a new set of nut plates to fix the tank to the rear crossmember. Rolling Eyes
Connected up the fuel lines, installed a battery and to my disbelief the engine turned over first turn of the key, good old 300tdi Rolling with laughter
Post #532539 17th May 2016 10:55pm
Nidge
Yes and 3 long days working on it and broke the back of it , weather was good too which helped
Post #532540 17th May 2016 10:58pm
Christian1402
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Indus Silver
Well this has moved on a bit from when I last looked!
Nice progress, what made you go with the pick up in the end? Any idea on colour?
Post #532778 18th May 2016 9:13pm
L110CDL
Cant beat a good dry few days to crack on with it Nidge Thumbs Up you cant get much better than the 300tdi imo Whistle 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #533018 19th May 2016 8:23pm
Nidge
Cheers Clayton Thumbs Up
Christian will be painting it the original colour which was red,
Decided on a pick up for number of reasons
Parts to convert to a station wagon are mad money (which was my preferred option and may happen some time in the future)
I Like the look of a red Pick up with a tan coloured canvas.
Perfect for the dogs and other wet gear etc.
The truck cab is quieter and heats up quicker on a winters morning.
And a hell of a lot less painting to do Rolling with laughter
Post #533056 19th May 2016 9:25pm
NickMc
Looking well now!
Got to say i've fitted a few Richards chassis and the fit and finish has left a bit to be desired, sticking to Marsland or genuine old stock.
The Agent for here is a prick too which doesn't help either :rolllaugh
Post #534700 25th May 2016 10:14pm
miker
I like the gantry crane! Great idea that. Care to share some costs and what materials you built it from? Sort of thing I could see myself making sometime in the future if I ever do a full rebuild.
Post #534727 25th May 2016 10:57pm
Nidge
Been a while since I have updated, so here we go
Lots of little bits done , rear cappings, brake lines, lights, axle breathers etc.etc.
Had to solder the rear loom back together as the Autosparks one I have on order has a 3month waiting list Shocked
Fitted the rear Tailgate using YRM stainless fittings, again top notch...
Reached a major milestone...got to drive it last weekend....Had it out for about 30mins, I must admit that first real push of the accelerator pedal was a bit nerve racking, what did I forget to tighten, but was impressed at how tight it was, temp gauge sat nicely to the left of centre, and no odd noises in the drive train Very Happy
Now to source a pair of doors and we are good to paint Thumbs Up
The scabby Ifor top is only a temp measure to keep the rain out, well most of it !!
Post #547167 8th Jul 2016 7:39pm
Nice. Great when it all looks in one piece and there are no 'chunks' of Defender lying around waiting to be fitted!
Love the 'gallows' Cool
Post #547229 8th Jul 2016 10:53pm
L110CDL
Some feeling when its all back together and you get to have a go and all is ok Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #547413 9th Jul 2016 8:49pm
Nidge
Sure is Clayton...
Fitted a set of Rock sliders today, installed the headlining and tidied up the wiring in the cab, new number plates and front grill. Starting to see the finishing line now.......except for that nagging feeling that I should paint it Nato Green instead of Portfino Red....Hmmmm
Post #547526 10th Jul 2016 1:33pm
L110CDL
Good that feeling seeing the finishing line Thumbs Up Nice rock sliders Nidge Whistle Well the way i see it (imo) is you should go with the colour you want as you will be living with it and hopefully its a keeper Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #547663 10th Jul 2016 9:49pm
