Home > Technical > 110 one piece drive shafts
Morepower
New Zealand
Hi guys... does anyone know where to get these from?... LR want £300 each plus vat.. Just looking for a replacement for the flanges to take some slack out of the drive system.
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #531408 13th May 2016 11:54pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Tim
You should try these guys, we used them to build HD props for the Bowler Thumbs Up
http://www.propshaftservices.com
HTH
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 250D XS
Post #531413 14th May 2016 4:21am
Morepower
New Zealand
Thanks John... But thats the prop shaft... I'm after the drive shafts (one piece)... I can find them for a 90 but not a 110... Or can you use the same part?..
Post #531425 14th May 2016 7:53am
geobloke
Hi Tim. Wondering if we are having a cross globe terminology issue here... Are you referring to the half shafts (diff to drive flange? Or the drive flanges themselves?
Did LR ever fit the one piece half shafts to 110s? If not are they rated high enoug for them?
Generally for cheaper parts you are best going to someone like Paddock Spares or LR-Direct. Most will do international postage.
Post #531435 14th May 2016 8:42am
Morepower
New Zealand
Probably a language barrier.. I'm UK based, So no international postage required.... I know LR changed to the single piece 1/2 shafts for the last year of production... My Bowler 90 has them (single piece) and I can get the LR part number for the single piece shafts... However at £289+vat Each I was wondering if there where any cheaper alternatives.
Post #531494 14th May 2016 2:55pm
Fatboy Slim
Wales
Same part 90 or 110. They're flipping expensive as you know. I'm trying to find them cheaper as well will keep you posted
Post #531536 14th May 2016 7:15pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
24 spline, one piece half shaft, like this?
Post #531542 14th May 2016 7:40pm
Morepower
New Zealand
That's them...
Post #531665 15th May 2016 10:14am
Disco_Mikey
Yea, they are available aftermarket for £90 a pair...
I keep a pair on the shelf at any time
Post #531668 15th May 2016 10:21am
sako243
You can pick up a pair of Ashcroft half shafts for that price (£300). Think that was for a Salisbury axle as I was looking recently.
Again I was looking at something different. Doh Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #531697 15th May 2016 12:14pm
JoeLouw
South Africa 2008 Defender 110 Puma 2.4 SW Orkney Grey
Info on this drive shaft
Hi Guys
OK so I came across this forum post in my search - so maybe this is not the right place to ask this, but I like top know what are the difference between these two images.
According to me, the Defenders come out with both Front and Back wheels/shafts looking like my sample photo - Front
FRONT
BACK
Joe
Post #608184 9th Mar 2017 6:51pm
mk1collector
The front has a seperate half shaft and drive flange, and the rear is a one piece halfshaft and flange Ray
My build thread
Post #608192 9th Mar 2017 7:48pm
JoeLouw
OK thanks for that info. I thought it might be one piece vs not one piece. But what does it do or benifit me to have one piece halfshaft?
Post #608196 9th Mar 2017 8:11pm
mk1collector
Having a one piece shaft and flange at the back just makes one less place for there to be slack in the driveline Ray
My build thread
Post #608201 9th Mar 2017 8:22pm
Disco_Mikey
Had a pair delivered yesterday, to replace one of my worn shaft/caps Thumbs Up
Post #608202 9th Mar 2017 8:24pm
