Home > Technical > 110 one piece drive shafts |
JoeLouw Member Since: 09 Mar 2017 Location: PTA Posts: 5 |
Thanks Ray, so what you saying is the one piece shaft is better?
10th Mar 2017 8:16am |
Miggit Member Since: 09 Mar 2017 Location: Milton Keynes Posts: 72 |
This may or may not help.. but did you know that some of the earlier RRC's had solid, not floating, drive shafts in the rear axle.... like these http://www.ebay.co.uk/itm/Range-Rover-clas...SwrklVNBfS
Part Numbers 571882 and 571883... and those are LR part numbers I didn't think they looked right either.. but they throw up a few results on a search.. and they even look like halfshafts RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
10th Mar 2017 10:30am |
I've just been on Microcat and spotted a slight flaw in my plan.. they are 10 spline shafts..
I believe that your looking for FTC3270 and FTC3271 RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
10th Mar 2017 10:35am |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Not necessarily. The advantage with the single piece is obviously one less joint to reduce slack in the overall drive. However, in a Two-Piece, if your half shaft snaps or for that matter sheds its teeth you can remove the half shaft, remove the prop to the rear and still be able to drive albeit carefully. If a Single piece snaps AFAIK you are I could be wrong and I am sure someone with greater experience may know something different. PS: With the possible greater amounts of torque being put on the half shafts, do you really want to go down the cheap route. I would go with Ashcrofts every time, but then I haven't had a half shaft go yet although I have spotted some fretting which Ive cleaned up and coated in a layer of High Pressure 'Blackjack' grease(although its got more consistency to tar!) |
10th Mar 2017 11:56am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16875 |
No reason not to do the same with a single-piece shaft, but you'd need to carry an old drive flange and centre cap if you wanted to be able to pull the shaft out and drive home.
Ashcroft HD halfshafts are warrantied against breakage but not against fretting. |
10th Mar 2017 2:39pm |
Just for info, as they've only just arrived. The Trek Overland ones aren't one peice shafts, despite having the one peice part numbers. They're just the earlier shafts with the later part number stuck on them by Bearmach. |
15th Apr 2017 3:26am |
