Home > Puma (Tdci) > Intermittent starting problem |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 |
yes I had the same first try your starter conections mine were both lose but then land rover also found a realay somewhere with bad connections
2nd Dec 2008 10:28pm |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
thanks - I'll check them out
3rd Dec 2008 12:22am |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
Perhaps we should club together and buy Land Rover some spanners. I've found all three door stay latches loose, a loose earth strap, a loose heat shield and a loose spare wheel bracket.
Bosun. |
3rd Dec 2008 9:58am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
cobs.our's did the same thing only once,I think it's a soft wear issue with the alarm. 2.4 90 XS
3rd Dec 2008 1:26pm |
Edd80Inch Member Since: 18 Oct 2008 Location: Devon Posts: 28 |
Yes I had the same on the dealers fourcourt when I took mine out for a spin, whith 3 miles on it. I put it down to the alarm and asked them to look at it.
Happened again the other day but just the once, and locking then unlocking cleared the problem. 1999 90 TD5 County 1943 Ford GPW Jeep |
3rd Dec 2008 6:36pm |
sounds like a trip to the dealer |
3rd Dec 2008 9:33pm |
El Cyd Member Since: 21 Sep 2008 Location: bristol Posts: 41 |
Not encountered it on the puma but my 300tdi has been known to do this (usually at the most inconvinient time and when maximum embarrassment is likely), resseting the alarm works on that too. If it aint broke its just waiting.
3rd Dec 2008 9:43pm |
hadenough Member Since: 22 Nov 2008 Location: salisbury Posts: 11 |
Hi
Yes we have this problem all the time this even happed even when LR enginer was test driving are vehicle it did it 3 times to him but as usual it still does it. So it looks like another trip to the dealer. |
4th Dec 2008 7:02am |
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 |
Hey I got the same ask dealer they said it how LR has made it, so if you get out leaving keys in it no one can then nick it. As it will not start or start and run for 5 to 10 sec then cut out and try starting it nothing take key out wait 30sec. Know the good bit it should start but 30 sec seem like a life time when you want to get going somewhere
Dave |
5th Dec 2008 10:02am |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 365 |
I leave the keys in mine all the time, iv'e never had this problem.
6th Dec 2008 11:58pm |
Is your key the 2008 type with the big black end parktag ? Dave |
7th Dec 2008 10:06am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
When you have this problem, release the Hand Brake and try again. If it cranks over and starts you have a bad earth between the chassis and battery
8th Dec 2008 5:59pm |
No, my key is the old design. As i said before i leave them in all the time without any problems and there's nothing in the hand book concerning this function. I guess theres a problem elsewere.
Sorry i can't be more help. 130 crew cab 98 V8 Disco |
9th Dec 2008 12:25am |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
Call me thick .
Something similar has happened to me but I put it down to this (an extract from the owners manual on page 15):
I haven't lost any sleep over it nor have I analysed it (too much of this happens at work ) Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
9th Dec 2008 10:15am |
