![]() | Home > Puma TDCi > Intermittent starting problem |
| simonpuma90 Joined: 16 Nov 2008 Location: south wales Posts: 54
yes I had the same first try your starter conections mine were both lose but then land rover also found a realay somewhere with bad connections |
| cobs Joined: 12 Jun 2008 Location: North Yorkshire Posts: 22
thanks - I'll check them out |
| Bosun Joined: 21 Jul 2008 Location: Great Berry Posts: 41
Perhaps we should club together and buy Land Rover some spanners. I've found all three door stay latches loose, a loose earth strap, a loose heat shield and a loose spare wheel bracket.
| Grockle Joined: 24 Nov 2008 Location: Derbyshire Posts: 104
cobs.our's did the same thing only once,I think it's a soft wear issue with the alarm. |
| Edd80Inch Joined: 18 Oct 2008 Location: Channel Islands Posts: 17
Yes I had the same on the dealers fourcourt when I took mine out for a spin, whith 3 miles on it. I put it down to the alarm and asked them to look at it.
| El Cyd Joined: 21 Sep 2008 Location: bristol Posts: 17
Not encountered it on the puma but my 300tdi has been known to do this (usually at the most inconvinient time and when maximum embarrassment is likely), resseting the alarm works on that too. |
| hadenough Joined: 22 Nov 2008 Location: salisbury Posts: 5
Hi
| dave's 110 Joined: 11 Jun 2008 Location: Norfolk Posts: 41
Hey I got the same ask dealer they said it how LR has made it, so if you get out leaving keys in it no one can then nick it. As it will not start or start and run for 5 to 10 sec then cut out and try starting it nothing take key out wait 30sec. Know the good bit it should start but 30 sec seem like a life time when you want to get going somewhere |
| parktag Joined: 30 Sep 2008 Location: Brittany Posts: 8
I leave the keys in mine all the time, iv'e never had this problem. |
| AndrewS Joined: 10 Apr 2007 Location: Pembridge Posts: 371
When you have this problem, release the Hand Brake and try again. If it cranks over and starts you have a bad earth between the chassis and battery |
No, my key is the old design. As i said before i leave them in all the time without any problems and there's nothing in the hand book concerning this function. I guess theres a problem elsewere.
| one_iota Joined: 06 May 2008 Location: Sydney Posts: 46
Call me thick |
| All times are GMT |
