Home > Puma (Tdci) > Fuel priming tool, where is it intended to fit inline? |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Been thinking about this myself. The LR tool (Part 310-110 IIRC) is expensive. There's a "Laser" aftermarket kit a bit cheaper. There's quite good coverage in the Workshop Manual.
This thread may be of interest http://www.defender2.net/forum/topic516.html I'll be doing my fuel filter replacement for the first time myself in a couple of weeks so watching with interest I'll be trying the fill-the-filter-first-and-change-quickly method first I think. However there's an attraction of having the bleeding tool in case I ever run out of fuel (maybe keep in the vehicle next to the jack/battery). Edit: The Laser 5262 kit (pic) is still £130 off ebay... Click image to enlarge The Sealey VS555 is about £20 more: Click image to enlarge As we know the LR genuine one is ~£280 here: http://www.dingocroft.co.uk/cgi-bin/ss0000...TION=Go%21 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 4th May 2016 8:55am. Edited 1 time in total |
4th May 2016 7:41am |
Done a bit of reading, seems like the pressure method is to remove the BLUE connector and collect it there.
Local LR mechanic says any air introduced in the disconnection/connection process should go through fine. Internet wisdom seems to agree. Anyway, soooo in the meantime I found that my breather tube was cracked below the little loopy thingy (the smaller one on the opposite side, i.e. not the fill breather). With a little fiddling the broke off even closer to the tank - so long story short >> it was filled with dirt and air tight! I don't recall either seeing a vacuum crumpled tank or hearing a hiss topping up diesel after a long drive (so that's er... good ? ) So now I'm thinking the hose might be broken at the tank end and apparently with a bit a bit of bolty undo-ey I can get to the breather connection without disconnecting the fuel lines ... Got some new fuel hose locally, can't imagine the slight difference in size will be an issue, considering it worked while blocked aaaand it's low flow air/vapour only. Should be interesting; obviously wont do the filter until this is all done. Solved the bowel problem, working on the consonants... |
4th May 2016 8:52am |
Oh hey, a question:
What is the little round and green knob near the blue connector? Guess is that it opens and closes the line to either fuel and or atmospheric pressure - not sure for what purpose though. Solved the bowel problem, working on the consonants... |
4th May 2016 9:01am |
agentmulder
you talking about this pic? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
4th May 2016 10:16am |
The circled part is the BLUE connector yeah.
In the background there is a green part that it connects to slightly further upstream. Solved the bowel problem, working on the consonants... |
4th May 2016 10:18am |
I thought the green was the pressure relief... i.e. if you pump too much fuel it releases from the green valve... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
4th May 2016 10:28am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Its all a complete waste of effort on a Puma anyway.
Simply fill new filter with diesel and swap old/new with minimum delay. Up the revs slightly for a good few seconds to clear any air that might have entered [if any] and jobs a good un ... Same as all other Puma engined vehicles ... We've done thousands and never had a problem Guns and Landrovers .... anything else is irrelevant. |
4th May 2016 2:41pm |
I agree.
Just engineering/mech talkin' it up ... Due to recent events it might be more relevant in my case though, small chance I may have to drain my tank Solved the bowel problem, working on the consonants... |
4th May 2016 9:01pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Agreed it you are local and help would be close to hand if required, however if you are going on an overland trip you definitely need to take one. http://www.defender2.net/forum/topic516.html 130's have feeling's as well you know |
5th May 2016 8:03am |
P33ETC Member Since: 11 May 2016 Location: Aberdeen Posts: 1 |
If it's of any use or if it helps someone reading this in the future; I had to remove my tank yesterday, replaced the fuel filter along with the small l/h breather and the larger fill breather on the r/h side as both were perished and broken. I filled the filter to the brim with fresh diesel before attaching and hunted Google on how to prime the system. There's still a lot to do on the motor before the weekend so ordering a priming bubble pump wasn't really an option, my first thought was to get an air line on to the small breather, open the fuel filler cap and clamp the return to the tank and disconnecting the fuel supply near to the pump.
As I stood staring in to space, I was looking right at the solution on the shelf in front of me; a vacuum pump!! Originally bought for doing oil changes on an onboard boat engine, it has a clear tube with an od of 8mm or so. Looking around, I found a bit of steel tube with an od of 9mm or so, a bit of electrical tape and a few pumps and it took fuel straight from the tank, through the filter, up the line right to the pump. I was worried sick all day in case I was going to damage something or be stuck with an air lock as some people were saying only the specialist tool would work and how hard it is to bleed the line etc but in under 2 minutes, the Heath Robinson primer had sucked a good 4l of fuel through effortlessly, plugged back in and engine running. Pheeew!!! |
11th May 2016 10:52pm |
Good job, seems like there are many solutions to this - including: doing nothing
I did the tasks as you over last weekend: fuel filter and the two breathers, my trick (if you could call it that) was the standard where you fill the filter and replace it quickly, as for the fuel line connections to the tank I quickly held them up high after disconnection so as to minimise fuel loss (which is replaced by air). Ran it at 1500 or so RPM for 2minutes then took it for a drive around the street in 1st low (keep revs high, but not get too far away from home). Worked for me at least Solved the bowel problem, working on the consonants... |
12th May 2016 12:38am |
Great posts guys thanks - my fuel filter arrived on Tuesday - a job coming up in the next days. Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
12th May 2016 6:30am |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 |
Thanks for the dimensions. I'll turn up one like the landrover tool on the lathe. I bought a bulb pump so just a bit to tubing to finish the job.
On replacement of the fuel filter, I topped up the new one with clean fuel and ran the engine with no need to bleed out any air that may have entered.however having the bleed tool to hand will be handy in future. John "You are never to old to learn something new" |
9th Feb 2017 11:35am |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 |
The way I do it is the same as others have done. No special tools and no rushing around worrying about air getting in either.
Just remove old filter, fill new filter with diesel from a very clean jar and push it up and turn. Job done. Start car and run at tick over for around 2 minutes and never had a problem at all, no hesitations no stopping, just smooth running. I think I had more palpitations changing the alarm fob batteries..... AlanH. |
10th Feb 2017 8:47am |
