Home > Td5 > C.V joints and swivel housings |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
I always rotate the the cv joint and add grease prior to fitting, there is a check to ensure you have the correct shimming, but I'm not sure off the top of my head. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
18th Apr 2016 12:36pm |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 |
Hi,
This is a well known topic, & there are some quite useful Youtube videos available which discuss the points you have mentioned. This is a good starting point: https://www.youtube.com/results?search_que...l+bearings You will find a lot of others related to this one. Cheers, Lionel |
19th Apr 2016 1:59pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7714 |
you can buy CV grease in 600ml carts for the grease gun, cheaper than one shot. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
19th Apr 2016 2:35pm |
19th Apr 2016 2:57pm |
