Home > Td5 > Ignition fed live |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 |
Is there a convenient ignition fed live in the engine compartment that can be used to support various accessories?
Is it safe to take a feed from the back of the cigarette lighter? 1999 Td5 110 CSW 1961 Series 2 88 LPG |
2nd Apr 2016 1:28am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
Click image to enlarge Click image to enlarge Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
2nd Apr 2016 3:59pm |
Ta muchly. 1999 Td5 110 CSW
5th Apr 2016 10:48pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2089 |
Only use one to switch a relay. It is not a good idea to run additional circuits off existing wiring as they are sized and fused for their original purpose.
A relay will only draw milliamps for switching so you could take a feed from the power socket, then you can run power to the relay from the battery and out into a fuse box where you can distribute it to the various additional circuits you wish to add. HTH Mo The Land Rover 90 - Many are called, few are chosen. |
10th Apr 2016 1:49am |
