Home > Puma (Tdci) > Help with 2.4tdci smoke |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
EGR valve? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
17th Mar 2016 8:53pm |
dannyc85 Member Since: 17 Feb 2016 Location: Middlesbrough Posts: 39 |
Iv taken the egr valve out and cleaned it also tried to run it with the egr unplugged but hasn't made any difference.
18th Mar 2016 1:55pm |
MAF sensor? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
18th Mar 2016 2:00pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2109 |
danny85,
Probably a silly question but what kind of smoke you have? Black, Blue or White? Smole appears when you accelerate or its all the time? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
18th Mar 2016 3:14pm |
Eduardo it's white smoke mate. It happens when I start the engine then disappears after 5 minutes then again for half a mile when first driven. It doesn't matter how long I leave the engine to warm it doesnt make a difference. It's a really massive cloud of smoke as well
18th Mar 2016 4:31pm |
MAF sensor has been cleaned with contacter cleaner. There are no fault codes showing?
18th Mar 2016 4:32pm |
Sorry smokes a lot worse whilst accelerating
18th Mar 2016 4:33pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3696 |
Has it been re mapped or tuned?
18th Mar 2016 4:59pm |
No just standard.
18th Mar 2016 6:02pm |
is lube oil level in sump increasing ?
next quenton the smoke color white ? smoke smell of diesel ? |
18th Mar 2016 6:13pm |
The oil level in the sump is fine it's never changed. The hose from in between the turbo and air filter to the engine is wet with oil same as the intercooler. Not loads of oil just a wet coating I was just wondering if faulty turbo gaskets could cause this. Yes mate white smoke and it smells
18th Mar 2016 6:44pm |
Depending of the ambient temperature a faulty glow plugs can cause white smoke, diesel odor during engine cold start, maybe can be that
18th Mar 2016 6:50pm |
Yes that could cause the smoke on start up but would glow plugs still cause smoke when driven even if the engine is warm?
18th Mar 2016 7:20pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7704 |
white smoke on a cold start up is normal in the colder days of late on them.
You starting it and driving off straight away? or leaving it 5mins then driving off and getting the smoke? (after initial start up) coolant is all good? whats mpg like? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
18th Mar 2016 8:29pm |
