Home > Maintenance & Modifications > Fitting a, X Defend -Column ignition barrel shield to a Puma |
Heliart Member Since: 11 Mar 2016 Location: Wiltshire Posts: 6 |
Interestingly, just working this same mod on my 2015.
Grinding the hold nice and neat is no problem I think, but surely the shield needs to be held in place/fixed, and as the shear bolt does not make contact with the barrel, that's an issue. Steve |
16th Mar 2016 5:15pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
if you pm dsc off he might let you in on the secret!he hasnt replied to my post and thats weirdly a year ago today!im not sure but go beyond might be a glue man!
16th Mar 2016 5:53pm |
BTW, I talked to Foundary4x4 today, they had no good solution, and suggested returning the unit if you have a 2015 model.
Cheers, Steve |
16th Mar 2016 7:39pm |
you got through to f 4x4..i couldnt and they did not rturn my e mails last year .....dsc does appear happy with his bodge perhaps give him a pm .........its really bad form by f 4x4 not to mention their product does not fit my15 and later models (as designed)
16th Mar 2016 8:59pm |
nicholas2012 Member Since: 28 Jun 2012 Location: lanarkshire Posts: 186 |
Looking for advice fitting this, has everyone fitted it with the light switch and indicator stalk wires running at left hand side underneath the x-eng column lock where the transmitter thing sits or moved the cables to right hand side of steering column?
15th Nov 2019 7:09pm |
When I did mine, the cables stayed on the left but the energiser ring ended up cable tied to the bottom of the steering column. Unfortunately, I forgot to take a picture of the completed installation but there's a few more details in my thread here: https://www.defender2.net/forum/post783667.html#783667 Darren
15th Nov 2019 9:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16938 |
^^^ Ditto when I fitted mine.
15th Nov 2019 9:10pm |
Thankyou for the info and link has been a good help
15th Nov 2019 11:02pm |
