Home > Maintenance & Modifications > Installing a heated windscreen |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 227 |
The windscreen can be had for around 150£ while the loom from e.g. MobileCentre (site sponsor) is about 100£.
Checked it some time ago and I don't know exact numbers anymore but it is around this figure. All in all a very welcome upgrade, all the Defenders here are fitted with one, wouldn't want to be without, esp. on the Td5 it is a very useful upgrade when the weather is damp. Peter, Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
8th Feb 2016 8:35am |
Gleaney Member Since: 03 Dec 2012 Location: Earth! Posts: 94 |
Thanks Peter. I have one in my Defender and it is very worth while. Thanks for the reply. Damn planet is short of Kryptonite !
8th Feb 2016 8:41am |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
One of the best value upgrades you can get!
I upgraded when my screen started to leak, around £150 + new seal and labour to get the screen fitted, I did the wiring my self with my own loom which probably saved at least another £50-£100. Worth every penny |
8th Feb 2016 10:14am |
Can anyone tell me if the wiring loom is there? It's a 61 plate. Damn planet is short of Kryptonite !
8th Feb 2016 11:55am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6487 |
No the loom is not in place unless your 90 has a heated screen from the factory. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
8th Feb 2016 12:36pm |
However if it's the one you have set in your profile, then it's a XS and should have a heated screen 1988 90 Td5 NAS soft top
2015 D90 XS SW |
8th Feb 2016 12:37pm |
No. It currently has a non heated windscreen from factory fitted Damn planet is short of Kryptonite !
8th Feb 2016 1:50pm |
Is it an XS? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
8th Feb 2016 2:13pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
Heated screen is only there with the winter pack (along with heated seats) is it not?
8th Feb 2016 2:22pm |
XS has winter pack as standard (certainly in the UK) 1988 90 Td5 NAS soft top
2015 D90 XS SW |
8th Feb 2016 2:25pm |
Is the heated windscreen bought as a pack with the screen, wiring and switch? Damn planet is short of Kryptonite !
8th Feb 2016 4:53pm |
An XS specification Defender normally has the following as standard, which is called the "Winter Pack" by Land Rover in the brochure:
Heated Windscreen Heated Seats So all the wiring and switches would be in place for those. This pack is (was) an option on other specifications. Any Defender that was not factory fitted with a heated windscreen will NOT have the wiring in place. OK for the pedants I'm sure there are a handful of exceptions to this where the line ran out of standard looms or whatever 1988 90 Td5 NAS soft top 2015 D90 XS SW |
8th Feb 2016 5:03pm |
Sorry for the confusion, I'm talking about the factory-fitted option.
For fitting after that, you can either buy the whole lot from one place, or the screen from someone and the loom from elsewhere, etc. I'm just a bit confused why you appear to have an XS without a heated screen. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
8th Feb 2016 5:08pm |
Thanks Martin. The heated windscreen is going into one which does not have the loom installed. So what I'm wanting to do is purchase the heated screen,switch gear and wiring kit to put one in.
Do you know where this could be bought? Damn planet is short of Kryptonite ! |
8th Feb 2016 5:16pm |
