Home > Maintenance & Modifications > Drain plug gunk , transfer box status assessment |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
Hi All,
So I have changed the oils on my puma 2.2 defender today. she has done 48,000Kms and a MY13 and I found this!: well, this is my first time doing oil change myself so please tell me how bad it is or its normal.... Click image to enlarge Click image to enlarge many thanks Martin |
5th Feb 2016 2:34am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Looks ok to me, you always get a small amount of swarf on the drain plug (magnetic for a reason). 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
5th Feb 2016 9:53am |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1633 |
Very surprised there is still swarf after 48,000 km and presumably at least 2 other previous oil changes??? YOLO... You Only Live Once...
5th Feb 2016 12:29pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
If you start finding chunks of teeth or synchro rings then you can be more concerned, but that is perfectly normal.
The LT230 is a pretty robust beast. |
5th Feb 2016 5:29pm |
Thanks everyone. that was a relief.
yes, this was the first oil change for gearbox, transfer box and both axles. in my case, 48,000kms in 3 years two big trips and approximately going offroad once a month: -the gearbox oil seems fine, the oil is dark red colored and doesn't smeel too bad. (I measure the dropped oil and mine was under-filled from factory) -the font axle oil is brownish black and the rear axle oil is also brownish black with quite a bit of bubbles in them. -the transfer box oil is the worse. it smells really bad and its sort of a think, also silvery black colored. I think I will be getting a magnetic plug for my gearbox soon and change the transferbox oil more frequently- workshop manuals says tbox oil changed at 80kkms and gearbox oil changed at 200kkms. Cheers Martin |
7th Feb 2016 11:38am |
