Home > Td5 > No heater air to the cab but heater working. |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1336 |
I have highlighted the cable and arms I've checked
[URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
20th Jan 2016 9:48pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1759 |
I have no help to offer I'm afraid, but what's that attached to your bulkhead? Looks line a sound liner?
20th Jan 2016 11:34pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Is it drawing air through the intake? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
21st Jan 2016 12:08am |
It's not mine, just a picture i 'googled' |
21st Jan 2016 7:43am |
Hi, yes, if i put my head to the wing air intake there's a lot of noise as if its sucking in lot of air. I'm that frustrated by it i'm going to skive off work for 1/2 hour once it's daylight and go investigate, i think it could be a stuck lever. Whilst i think i'm fairly mechanically minded, i've never had a Td5 and not had a defender for 7 years and that never had any issues. Give me a mk3 escort and i can identify them part for part |
21st Jan 2016 7:49am |
calum Member Since: 06 Dec 2014 Location: Aberdeen Posts: 46 |
Remove the wing top grille and check it's not full of leaves or organic matter and water? Also check that the drain hole in there is clear at the same time.
Calum |
24th Jan 2016 12:50am |
The first thing I would check is that you have water in the radiator. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
24th Jan 2016 2:54pm |
