Home > Technical > Puma 2.4 injectors - need to worry after 80.000km ? |
Quoting from the current edition of the french periodic "LandMag"...
The weakest point of a Puma 2.4 are the injectors, which need to be inspected every 80.000 km, because their bad functioning may cause a total engine failure. Is this a known problem, should it be a concern, and could it be checked? And if so, how can a main dealer check if all is ok if at 80.000 km there is nothing going wrong yet? I am having 79.000ish km now, so time to ask this on here. Eric Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 9th Jan 2016 11:22am. Edited 1 time in total |
9th Jan 2016 10:49am |
Thanks Blackwolf, I am asking because for me this is also a first to read such statement.
Eric Euhh, now that I come to think of it, Caterham, to be on the safe side I would immediately check yours. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
9th Jan 2016 11:14am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6266 |
work in progress. just waiting for the seals and new bolts to arrive. suspect an intermittent sticking valve might be the problem (sometimes sounds on initial tick over like it's running on 3+1/2 cylinders, and clattering sound while on the move (sounds like injector noise and stops as soon as you take foot off the gas - so not sure if that could be a sticking valve or not?) ....one day....one day. - until then I live in hope. |
9th Jan 2016 11:39am |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
I know it's a fairly common problem on the 2.0l TDCI engine as fitted to the Mundaneo etc etc (Spelt incorrectly I know ) But have never heard anything about it on the 2.4 or 2.2 engines..
I believe on the 2.0 ford even released a software patch to help cover the issue..As it was something to do with injector wear causing diesel knock due to over fuelling Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
9th Jan 2016 12:49pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
We've had two die from melted pistons due to injector faults. Will try and find the photos.
9th Jan 2016 2:00pm |
