Forum · Gallery · Sponsors
Home > Technical > Slight grinding sound from the rear in 6th gear
Reply to topic  Down to end
moodyfay
Switzerland 2007 Defender 110 Puma 2.4 CSW Manual Stornoway Grey
I have a 2007 Defender 110 (puma) and have had no problems with the car since new. I have covered over 45'000 kms with it and the car has started making a grinding sound that seeems to originate from the rear when cruising at motorway speeds in 6th gear. However, the grinding sound only occurs when I lift my foot off the accelerator pedal and only when cruising at over 130 km/h.
Do you guys have any ideas for me?! I really appreciate it, thanks
Moody
Post #4817 19th Nov 2008 12:10pm
View user's profile Send private message Reply with quote
mrwoo
2007 Defender 90 Puma 2.4 CSW Manual Zambezi Silver
130KM or 80MPH is quite excessive.
Post #4818 19th Nov 2008 12:51pm
Sonic3d
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Manual Bonatti Grey
Sounds like the rear diff to me
_________________
D3 Gone A5 Quattro Rocket Arrived + 90 County HT Gone 110DC XS Arrived
Post #4823 19th Nov 2008 1:23pm
Japseroony
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Manual Java Black
It could be the rear propshaft. When the UJ's get worn the prop can vibrate (actually they do this from new but dont usually rumble) causing a rumble sound especially upon decelaration (sounds similer to a bearing going).
Get underneath and have a look at the joints and also check the bolts are tight.
Russell.
Post #4824 19th Nov 2008 2:45pm
moodyfay
Thank you Russell,
I will get under the car this weekend for a look. Will keep you posted!
Moody
Post #4855 21st Nov 2008 5:29pm
felos
Greece 2008 Defender 110 Puma 2.4 CSW Manual Epsom Green
In my car it was the rear diff.It developed exactly the same problem at approx.5000km and gradualy the noise started to appear at 4th ,5th and 6th gear from 80 to 130 km/h.
The local dealer changed the front diff the transfer box and both propshafts before shorting it out (poor thing).
Hope that helps.
George
_________________
NOT A TRANSIT
Post #5034 26th Nov 2008 6:07pm
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2009 Martin Lewis
