Home > Td5 > Headlight switch turns alarm on not headlights .plz helpHelp |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Could be a bad earth somewhere
21st Dec 2015 8:03pm |
Collydog Blue Member Since: 06 Dec 2013 Location: Stockport Posts: 26 |
Thanks jay, got the steering colum housing off looking around as we speak,
21st Dec 2015 8:23pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
Under bonnet on bulkhead undo nut and clean all connections
21st Dec 2015 8:30pm |
also try unplugging towing socket driver side back wheel arch
21st Dec 2015 8:38pm |
Thanks everyone, still no joy, will try the above thanks again.
Just found oil in my ECU plug now.... ... |
21st Dec 2015 9:00pm |
time for new injector harness and brake cleaner as well
21st Dec 2015 9:14pm |
Thanks Dorsetsmith, I'm gutted, only had it done last year.
21st Dec 2015 9:23pm |
in that case check head end for oil if none seen, clean red plug out with brake clean
had to do my one sume year ago to take at lest month to get oil out of the loom |
21st Dec 2015 9:30pm |
Will do, thanks for your help.
21st Dec 2015 9:39pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
I had the same problem when I accidentally connected the positive headlight feed to the ignition negative (long story)... Anyway, it blew a fuse and I had to do an emergency field repair
Click image to enlarge Check that fuse under the driver seat, first long one on the right |
21st Dec 2015 10:57pm |
Thanks mrd1990, I did check my fuses last night, but it was dark and I did have my stress head on, will have a closer look today when the stress monkey has gone. Thanks again.
22nd Dec 2015 7:16am |
Well, checked all joints, fuses, and cleaned oil out of ECU plug still no luck, also tried disconnecting the battery to see if it would reset it, but still the same problem.
Going to start from scratch tomorrow checking all joints again, and bulbs etc, if anyone has any other ideas I would be eternally grateful. |
23rd Dec 2015 5:32pm |
