Home > Td5 > Headlight switch turns alarm on not headlights .plz helpHelp
Collydog Blue
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
Help.. Came to drive off in my 1999 TD5 last night, Alarm wasn't active, jumped in, started engine, but as I switched the lights the alarm sounded, but no lights.
Alarm stopped sounding when lights were switched off, but sounds every time lights switch is activated, and no sign of any lights.
Plz help Big Cry
Post #484241 21st Dec 2015 7:54pm
JAY BOY
Wales
Could be a bad earth somewhere
Post #484243 21st Dec 2015 8:03pm
Collydog Blue
Thanks jay, got the steering colum housing off looking around as we speak,
Post #484247 21st Dec 2015 8:23pm
Romadog
Under bonnet on bulkhead undo nut and clean all connections
Post #484248 21st Dec 2015 8:30pm
dorsetsmith
also try unplugging towing socket driver side back wheel arch
Post #484249 21st Dec 2015 8:38pm
Collydog Blue
Thanks everyone, still no joy, will try the above thanks again. Thumbs Up
Just found oil in my ECU plug now.... Censored ...
Post #484254 21st Dec 2015 9:00pm
dorsetsmith
time for new injector harness and brake cleaner as well
Post #484259 21st Dec 2015 9:14pm
Collydog Blue
Thanks Dorsetsmith, I'm gutted, only had it done last year.
Post #484263 21st Dec 2015 9:23pm
dorsetsmith
in that case check head end for oil if none seen, clean red plug out with brake clean
had to do my one sume year ago to take at lest month to get oil out of the loom
Post #484266 21st Dec 2015 9:30pm
Collydog Blue
Will do, thanks for your help. Very Happy
Post #484275 21st Dec 2015 9:39pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I had the same problem when I accidentally connected the positive headlight feed to the ignition negative (long story)... Anyway, it blew a fuse and I had to do an emergency field repair
Check that fuse under the driver seat, first long one on the right Thumbs Up
Post #484309 21st Dec 2015 10:57pm
Collydog Blue
Thanks mrd1990, I did check my fuses last night, but it was dark and I did have my stress head on, will have a closer look today when the stress monkey has gone. Thanks again.
Post #484348 22nd Dec 2015 7:16am
Collydog Blue
Well, checked all joints, fuses, and cleaned oil out of ECU plug still no luck, also tried disconnecting the battery to see if it would reset it, but still the same problem.
Going to start from scratch tomorrow checking all joints again, and bulbs etc, if anyone has any other ideas I would be eternally grateful. Crying or Very sad Crying or Very sad Crying or Very sad
Post #484856 23rd Dec 2015 5:32pm
