Home > Technical > Td5 battery flat - alarm goes off when i try to charge
shaggydog
Hi guys,
The Td5's batter has gone flat. Like pancake flat not enough charge to unlock when pipped with the remote.
I get in and put the charger on it and the alarm sounds.
if I take the battery off to charge it the other alarm (BBUS) sounds.
Now it wont do anything and I cant charge it.
What do I do as I need to move it?
I don't have a nannocom or anything like that to plug in a switch it off, not that I can as the battery is dead.
Looked in the owners manual and it doesn't say what to do if the battery is flat in the vehicle. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #483699 19th Dec 2015 3:24pm
dorsetsmith
with td5 BBUS sounds. fitted if you disconnect battery it will sound the alarm ok
can start the land rover ? with the new battery fitted ?
Post #483708 19th Dec 2015 4:22pm
shaggydog
I managed to get the battery out (nobody had greased the terminals and they were welded on)
So now charging the battery out of the vehicle so at least I know battery is good. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #483709 19th Dec 2015 4:27pm
shaggydog
Ok just to update.
Charged the battery and got it checked and it has come back saying all is well with it so now just need to refit.
I put the positive on and nothing, as soon as I touch the negative the alarm goes off.
What am I doing wrong and how do I stop the alarm going off while refitting the battery? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #483996 20th Dec 2015 6:49pm
dorsetsmith
do you have alarm key fob if so press unlock button
Post #483999 20th Dec 2015 6:52pm
shaggydog
I do indeed so will give it a go tomorrow Thumbs Up
What happens if it keeps going off while I press unlock? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #484005 20th Dec 2015 7:20pm
dorsetsmith
close all door and window bonnet too set the alarm (padlock symbol) with key fob red light flashing in the (dash) and then unset it this should clear it Thumbs Up
with starter switch to position II Exclamation
Post #484014 20th Dec 2015 7:39pm
shaggydog
Smashing thanks for that Thumbs Up
Hope to get it sorted tomorrow Very Happy Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #484015 20th Dec 2015 7:43pm
