Home > Technical > Td5 battery flat - alarm goes off when i try to charge |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Hi guys,
The Td5's batter has gone flat. Like pancake flat not enough charge to unlock when pipped with the remote. I get in and put the charger on it and the alarm sounds. if I take the battery off to charge it the other alarm (BBUS) sounds. Now it wont do anything and I cant charge it. What do I do as I need to move it? I don't have a nannocom or anything like that to plug in a switch it off, not that I can as the battery is dead. Looked in the owners manual and it doesn't say what to do if the battery is flat in the vehicle. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
19th Dec 2015 3:24pm |
I managed to get the battery out (nobody had greased the terminals and they were welded on)
So now charging the battery out of the vehicle so at least I know battery is good. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
19th Dec 2015 4:27pm |
Ok just to update.
Charged the battery and got it checked and it has come back saying all is well with it so now just need to refit. I put the positive on and nothing, as soon as I touch the negative the alarm goes off. What am I doing wrong and how do I stop the alarm going off while refitting the battery? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
20th Dec 2015 6:49pm |
do you have alarm key fob if so press unlock button
20th Dec 2015 6:52pm |
I do indeed so will give it a go tomorrow
What happens if it keeps going off while I press unlock? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
20th Dec 2015 7:20pm |
close all door and window bonnet too set the alarm (padlock symbol) with key fob red light flashing in the (dash) and then unset it this should clear it
with starter switch to position II Last edited by dorsetsmith on 20th Dec 2015 7:57pm. Edited 1 time in total |
20th Dec 2015 7:39pm |
Smashing thanks for that
Hope to get it sorted tomorrow Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
20th Dec 2015 7:43pm |
