Home > Td5 > Compression test |
BecauseLandRover Member Since: 27 Oct 2015 Location: Portsmouth/Cambridge Posts: 17 |
Hi, we used this kit from Snapon, had everything we needed.
Click image to enlarge Removed engine cover, air intake, bits that get in the way. Then removed the glow plugs. I think we did it one by one the plugged the pressure gauge into the port for the glow plug and cranked the engine. Click image to enlarge There are no exact pressures listed by LR, you are looking for major pressure differences. We found the issue on cylinder 1-leading to head gasket failure. Click image to enlarge Click image to enlarge Click image to enlarge I would also pick up the Haynes manual as it's very useful if you don't have one already, so much quicker than trawling the interweb on your phone with oily hands. Click image to enlarge Hope that helps a bit |
2nd Nov 2015 10:03am |
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 |
Yes that's great thanks, when looking for a compression tester, do you know what size adaptors you used, I've been looking at some kits, not Snapon as this would be very expensive, but they only list manufactures, not model specific, any help would be appricaetd so that I don't buy the wrong kit
2nd Nov 2015 8:21pm |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
I have to ask, how do you check the compression on all five cylinders via the glow plugs? It wasn't me!
2nd Nov 2015 10:54pm |
It was a couple of weeks ago now, but I reckon it was m10 thread an 4" long adaptor. didn't actually get any clear shots of the compression test as I was cranking the engine over from the cab. It's a two person job really unless you have a gopro or something.
Sorry I can't be more helpful. If you end up doing a head rebuild I can help with further advice as I have just been part of that process. My rad and thermostat were stuffed-leading to massive overheating and gasket cooking. |
2nd Nov 2015 10:57pm |
What I'm aiming at, is the ratio of cylinders to glow plug disparity. It wasn't me!
2nd Nov 2015 11:00pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 541 |
The only way to correctly do a compression test is to remove the injectors and fit a compression tester inplace of the injector as there is only 4 glow plugs on a Td5,
Regards Will 2005 90 XS 1954 86'' Series 1 tilt |
2nd Nov 2015 11:06pm |
I could only do 4-was enough to find the issue with mine.
2nd Nov 2015 11:18pm |
That's what I was trying to get to, without picking an argument.
As for the correct adaptors for the injector openings which is what the OP asked, I haven't located the correct ones yet. Then again, I haven't looked that hard. It wasn't me! |
3rd Nov 2015 1:18am |
http://www.sealey.co.uk/PLPageBuilder.asp?...results=16
It'll be something like this at a guess. It wasn't me! |
3rd Nov 2015 1:27am |
I do see your point ozzy. I'm not being argumentative either. I appreciate the fact that there is a correct way to do it.
It's been a learning curve for myself and my friend. |
3rd Nov 2015 10:05am |
You need something like this one : http://www.sykes-pickavant.com/products/co...ssion/2250 the push on one is only for petrol due to the high compression pressures in a Diesel it
would not be suitable. Will 2005 90 XS 1954 86'' Series 1 tilt |
3rd Nov 2015 1:55pm |
Good shout there, like I said, I hadn't looked all that hard for one. It wasn't me!
3rd Nov 2015 5:42pm |
Thanks derbywill
3rd Nov 2015 7:20pm |
