Home > Td5 > help with starting a td5 when hot |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Injector seals are hugely common, and the first place to start, but usually give cold start problems too
Next time it doesn't start, go through the fuel bleed sequence, see if it starts any easier Also check the injector loom and ECU for oil ingress |
18th Aug 2015 9:43am |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Thanks, will remove the drivers seat and check the ecu and google how to check the injector seals. Are you disco mike of disco3.Co.uk too?
18th Aug 2015 10:01am |
What do you do with the keys when you stop it?
When you're re-arming the immobiliser, are you taking the keys out, locking and unlocking? They can be a bit finnicky and not properly disarm themselves. |
18th Aug 2015 1:08pm |
The very one Seals can't really be checked. Best bet is to replace them, and check the head while injectors are out. Stick with OEM or genuine seals. There is not a huge difference in price, and it eliminates them, instead of 2nd guessing what quality they are |
18th Aug 2015 5:05pm |
Just incase it helps out anyone else reading this using a search feature in the future, it was a lazy starter motor 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
1st Nov 2015 4:54am |
