Home > Td5 > Td5 Hesitating on pickup |
Take a quick look at the red plug etc and perhaps give the MAF sensor a squirt of electrical contact cleaner.
12th Sep 2015 12:22pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2880 |
No oil present
12th Sep 2015 12:35pm |
It was a thought. Sometimes mine is a little hesitant from a start, cold or warm, and it's my daily driver. I put it down to a sensor somewhere still slumbering away. If I am in the frame of mind a stop and restart and all is fine, other times it will just pick up after a couple of hundred yards with a fair amount of throttle then it feels like everything "comes on line"
12th Sep 2015 1:31pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5430 |
Sounds like a failing MAF sensor.
Andy |
13th Sep 2015 6:54am |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 311 |
Just as a bit of fault diagnosis, have a look at the fuel pump relay under the drivers seat.
I had an intermittent fault with the relay causing the fuel pump to stop, identified as the relay as it was hot after starting and had evidence of arching on the terminals. Relay replaced, fault sorted. Worth a look. Sandy |
13th Sep 2015 7:29am |
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 |
Mt immediate thoughts are as above, oil in the loom or MAF sensor, if you've checked the loom and its clear, check the MAF sensor, 60 second job. Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
14th Sep 2015 1:47pm |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
Is it hesitating under light load as in gentle starting off cruising or heavy load like when accelerating up an incline??
16th Sep 2015 3:30pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Just disconnect your MAF sensor and drive a bit with it and see if it is any better. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Sep 2015 5:28pm |
Just accelerating on flat road
16th Sep 2015 7:29pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Have you tried the turbo wastegate actuator? It might be sticking, spray it with 3 in 1 oil or PTFE fortified light oil and try to free it if it's stuck.
Then check the MAP sensor on the inlet manifold too. |
16th Sep 2015 9:49pm |
As Lambley I too was also thinking of the waste gate sticking. About every 6 months mine sticks and shows up as hesitation when accelerating.
16th Sep 2015 10:05pm |
