Home > Off Topic > tin tent fridge
Caterham
tin tent fridge
Hi
Just got to campsite with tin tent and it would appear the dometic fridge aint working on gas.
There's a little inspect window and I can see the pilot light and ignition working. So to get the gas to light you have depress the temp control know and then let go once light (I always wait 10 secs) but each time I let go of knob the gas goes out.
Failed thermo couple?
Post #450202 28th Aug 2015 9:04pm
ickle
On the old 3 way fridges we used to fit in the Autosleepers, you could remove and clean the thermo couple fairly easily,
But remember you're playing with gas, not sure if Gase Safe applies these days.
Keith
Post #450205 28th Aug 2015 9:24pm
grafty99
Very likley the thermocouple. No gas safe for caravans but instead the GSIUR (Gas Safety Installation & Use Regulations) but to be fair I think as long as you are competent there shouldn't be any issues. Although I take no responsibility for you going boom in the night! Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #450220 28th Aug 2015 9:59pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
Try removing the gas knob, and packing the inner with a small piece of paper.
Sometimes the valve does not make a good electrical connection due to the knob hitting the valve before making the connection. (We are only looking at milli volts).
You could also try lighting with the knob removed.
If after trying this you still have the same issue it is your thermo-couple.
Hope this helps. You only have one life, live it....forget the cost.
90XS Hardtop
Post #450226 28th Aug 2015 10:21pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Remove the lower vent on the out side, you should be able to get to the burner, check that it is clean , get someone to try and ignite the fridge and check the colour of the flame, it should not be yellow. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #450240 28th Aug 2015 11:42pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Mines doing the exact same on gas, let the knob go and the wee needle drops away again. I put the 'van in for a service and told them about this, and the cooker not working on gas either - when I got it back they said I needed the fridge and cooker looked at - well duh! Not happy with their 'service' at all.
Post #450243 29th Aug 2015 12:31am
ARC99
A lot of caravan service centres do not have staff trained to work on bottled gas due to the costs of training and repeated training and testing.
I took mine into a main dealer in the North East about 8 years ago, when I booked the service they had a full list up in the reception of what a full service covered, when I arrived with the caravan they gave me a list of what they do under service, they had crossed out all checks on gas appliances and those that use 240 volt electric. It didn't leave much else for them to do. They had not altered the cost and when I questioned this they offered to knock off £20.00 from £200.00, I hitched up and drove off.
I now used qualified gas (portable appliances) engineers with liability insurance to service the fridge, cooker and water heater and qualified electricians with portable appliance cover to do the electric side of the van. The local Dometic service engineers are qualified for both gas and electric . Don't make old people mad.
Richard
Post #450324 29th Aug 2015 12:42pm
Caterham
Thanks for the replies. Back of fridge clean.
Will have a look at know / paper idea.
Post #450338 29th Aug 2015 2:10pm
