Home > Technical > Engine driven pto
Landscope
Engine driven pto
Hi there I am looking for some help!!
I have a gritter / tipper 130 and am looking for a hydraulic engine driven PTO kit to fit the 2.2 puma /tdci engine.
has anyone ever seen this ??
many thanks
Brian
Post #448854 24th Aug 2015 10:11pm
Cupboard
Never seen one fitted to the engine, (though it should be possible). Plenty fitted to the PTO on the transfer box, and there's one in the for sale section currently.
The issue with that is it's not independent of ground speed, it runs at a fixed ratio to wheel speed.
Post #449355 26th Aug 2015 1:01pm
shaggydog
Actually far from it, you knock your transfer box into Neutral and then you have 5 forward speeds at tick over to sit at or 1 reverse speed at tick over and can sit with the handbrake on Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #449379 26th Aug 2015 1:27pm
Romadog
I have an unused hydraulic PTO kit driven from transfer box surplus to requirements............... Whistle
Post #449470 26th Aug 2015 6:19pm
Cupboard
OK, it's independent if you're not moving/out of gear Laughing
And I guess you've got the choice of high/low.
Post #449678 27th Aug 2015 12:56pm
shaggydog
Laughing Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #450046 28th Aug 2015 1:07pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Isn't the issue with the puma models to do with a chassis crossmember sitting directly in the way of the transfer box take off?
I'm sure thats why the utilities companies went away from hydraulic and PTO winches. Fitting hydraulic pump elsewhere (belt driven) was seen as too much like hard work.
Post #450213 28th Aug 2015 9:43pm
Fossil
United Kingdom 1997 Defender 110 300 Tdi CSW Coniston Green
There used to be a kit advertised on ebay, I think it was Flowfit who used to do one for the 2.4. They certainly have the bits.
Post #452269 4th Sep 2015 7:55pm
newhue
Australia
Post #457853 24th Sep 2015 8:39pm
What are most of you looking to power from it?
Post #457868 24th Sep 2015 8:59pm
Cupboard
newhue wrote:
First Four, pricey, but nice.
http://www.firstfour.co.uk/products/hydraulic-drive-systems
If you price up a hydraulic winch vs a high end Warn winch there's not that much in it.
Post #457885 24th Sep 2015 9:28pm
newhue
Australia
I was looking at a winch, but it just becomes to expansive for how much I use a winch. I have a mate with a a PTO winch off his Tdi I have been looking at for the Tdci, but it's still not clear if it will fit. And its still its still not a cheap option with various alterations needed be made. I'm not a fan of expansive electric winches, water is water not matter how much you pay. My Defender and travels
Post #458116 26th Sep 2015 5:27am
theorangebandit
Here's one kit and not the one I found originally a year ago when I become interested in a pto
eBay Item No. 181785104312
I searched transit pto
Post #458135 26th Sep 2015 8:58am
