![]() | Home > Maintenance & Modifications > Puma airbox removal |
| Eduardo Joined: 28 Aug 2008 Location: SANTIAGO - CHILE Posts: 130
Miserableolgit,
| Miserableolgit Joined: 14 Sep 2007 Location: Suffolk Posts: 70
Thanks Eduardo but I got to that stage without problem. It's the filter housing itself that I want to get out but it refuses to budge even after removing its supporting bracket bolts etc. |
| AndrewS Joined: 10 Apr 2007 Location: Pembridge Posts: 371
It needs to be pulled up at the place where it is closest to the engine then pulled horizontally away from the wing. |
Well I've again pulled, heaved, yanked, attempted to lever and generally applied as much force as I dare and even with spraying the rubber grommets with lube the thing still refuses to budge. I think I'll end up drilling out the pop rivets that hold the upper bracket in place. |
Well all I can suggest is eat more for breakfast and then have a really good tug. Up and towards the engine that is. |
| TimmyNZ Joined: 05 May 2008 Location: Western Australia Posts: 28
This is what the book says:
Many thanks for that Tim, I had overlooked the 3rd bracket fastener behind the the shock turret and obscured by mud. All sorted now.
You're welcome Steve!
| Edd80Inch Joined: 18 Oct 2008 Location: Channel Islands Posts: 17
In short its a basta*d |
| parktag Joined: 30 Sep 2008 Location: Brittany Posts: 8
I can't even get the top off the air box. It's a LHD and the air box is right under the right hand side wing. I spent an hour trying,but couldn't do it. Now i'm worried that when it goes to the local ford garage for it's first service (in France) they'll just not bother changing it or they'll bend the wing. Is anybody elses under the wing? |
| All times are GMT |
