Home > Puma (Tdci) > Defender PUMA = unstopable. Dune driving suggestion. |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
They call West Australians sand gropers, for good reason. Every one I know drops their tyre pressures in the dunes over here as on most rough surfaces. In most areas you are advised to drop the tyre pressures for the sake of yourself and other track users. I have found lowering pressures gets me off beaches when the higher pressures will not.
Allan |
5th Dec 2010 1:32am |
Ninetenths Member Since: 26 Mar 2009 Location: Sarf Lundun Posts: 161 |
True enough and also long range fuel tanks. The pink panthers were actually lowered to make them more covert. Pimped black '07 Puma Equally Pimped Black Pick up Truck Rollin deep |
9th Dec 2010 5:07pm |
siwady Member Since: 28 May 2015 Location: Dubai Posts: 22 |
Can anyone guide me on how to remove the ABS/TC fuse on my 2012 Defender.
Is it located under the passenger seat or the the box under the steering wheel. Would appreciate a picture as I am not the technically inclined |
28th May 2015 10:46am |
