Home > Technical > 300 TDi cut out switch |
Nope never heard of one
started to overheat or overheated , there is a big difference to what could be wrong |
21st May 2015 7:41pm |
Never heard of, but it would not be hard to make it.
Plumb in an adjustable thermostat fan controller, let the controller activate a "break type" relay to cut out the fuel solenoid. Set the adjustable controller to a temperature slightly higher to the max. temperature you think the engine has to cut out. And for safety reasons, add an override switch to the relay. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
21st May 2015 7:51pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7701 |
no there isn't one fitted as std. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
21st May 2015 10:26pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
^^+1 No such thing fitted as standard. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter |
21st May 2015 10:49pm |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
This might take a bit of plumbing.
The puma / dura torque engine is fitted as standard with a thermal cut out switch. It`s on the back of the cylinder head NO 4 cylinder. You could, if you desired some how plumb it into the cooling system, head or block area. Then run in series thru to the fuel pump fuel cut off solenoid. When the engine over heats. The circuit is broken and it cuts out. A bit drastic if you ask me, a warning light or buzzer would be better. To warn of low coolant level. Excuse the spelling I`am better with spanners and wires. |
25th May 2015 8:35pm |
