Home > For Sale & Wanted > [Wanted] Td5 radio bezel |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
I have the radio bezel and the wire retainers currently fitted in our TD5 but will soon be removing to fit a MUD fascia plate. However will have to wait until I source a new radio. It is missing one of the two spring clips which hold it in however, you can get these easily though.
Your welcome to it for the cost of postage if you can wait a month or so? Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
12th Nov 2014 6:02pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 710 |
Hi, hmm, not to sound impatient or anything, but ive got a trip to Scotland coming up in a couple of week and could do with one before then, thank you for the offer though, and let me know if you get it out before
12th Nov 2014 6:11pm |
I think when I bought one they were only about £10 or so from a landy Indy new
12th Nov 2014 6:18pm |
daingeanrob Member Since: 21 Dec 2014 Location: sligo Posts: 27 |
Hi All, first post so might be cheeky, but if you still have the radio bezel and spring clips i would love to get them if you changed to the mud console? alternately does anyone know how i could get all the part numbers required or is there a stereo fitting kit available for the td5 dash? i currently have no radio.
21st Dec 2014 2:39pm |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 |
I was looking for one a few months ago and couldn't get one at a reasonable price, so glued the broke one and then fixed it I place using black silicone. Not my first choice, but worked fine.
21st Dec 2014 8:01pm |
can't find one either, but i don't have one to glue together, i believe my poverty spec defender never had an original radio.
21st Dec 2014 8:19pm |
Ye Gods, I had to replace mine about 5 years ago it cost me just under a tenner, just did a quick search for;
BEZEL, BLACK, RADIO Part number: FHF000070PMA They're anything from £30 upwards! This is along the lines of the front fog light switch that went from around £8 to over £50 near enough overnight! |
21st Dec 2014 8:57pm |
cheers for the part number, does anyone know if that includes the clips/fastenings or do i need to buy more than just this?
21st Dec 2014 11:27pm |
I think that it's a case of double checking with the seller, mine came with them but I don't use the wire thingys and my head unit stays in place quite tidily but allows me to pull the whole radio panel out to gain access to the wiring behind there.
21st Dec 2014 11:45pm |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 276 |
Had to do mine a couple of years ago and all the parts were separate. From my notes at the time:
Radio securing Wire-trim retention FBT000020 approx. £1.47 each Switch panel is FWJ000110PMA was £16.49 Opening for radio is Bezel FHF000070PMA approx £4.86 Clips either side of bezel are ‘clip facia with radio defender’ EYC106690 Those prices were from 2012. Tony |
23rd Dec 2014 1:58pm |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 |
My 2003 TD5 radio bezel broke since last owner, I already order the new bezel and the retaining clips and wire( not sure if I going to need this parts), I'm now looking for instruction to remove the broke bezel and replace a new one, would anyone give me some tips for doing it, so i will not brake it during installation!
Thanks Last edited by RF3777 on 20th Apr 2015 2:48am. Edited 1 time in total |
19th Apr 2015 6:13am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
You will need to get to the back of the facia plate.
Remove the dash top pad by unscrewing the top vent covers, the airflow control levers on the drivers side, and the passenger side grab handle (you need to prise out the little Land Rover logo to access a screw on that end). Then remove the two screws in the bottom of the fascia - loosen the 3 along the top. It'll then slide out. Next steps are easier to just remove it - so disconnect all the switch connectors and you can seen how the clips and wires are arranged. Hope that helps! |
19th Apr 2015 7:59am |
Anderzander
Thank you for the quick instruction, I will look into that once I get home, hope everything go smooth! will get back to the post ! |
20th Apr 2015 2:51am |
