Home > Maintenance & Modifications > Mudflap removal from bracket! |
Drill the rivets out and replace with domehead stainless bolts. I did when I detached mine and moved them outwards.
Entreq used to do stainless brackets at a price though. Speak to Brendan as I think Nakatanenga do them. If they do they will be excellent quality and Brendan can get them. Brendan is 'Leeds' on this forum, he is a sponsor or you can contact him here: http://www.4x4overlander.com/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 18th Apr 2015 11:11pm. Edited 3 times in total |
18th Apr 2015 8:58pm |
Drill out or grind off back of rivet
you can get cheap replacments , just repaint them with better primer/paint beford fitting Or buy expensive stainless ones |
18th Apr 2015 8:59pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
Dont pay £90 for stainless( you can get a gavo set from various sources for <£20...bit of paint and your off http://www.rimmerbros.co.uk/Item--i-MUC3986__7BP http://www.lrparts.net/rear-defender-90-mu...-pair.html |
18th Apr 2015 10:07pm |
or you could go for ali ones at £16 plus VAT:
Click image to enlarge http://www.yrm-metal-solutions.co.uk/epage.../008A-0005 |
19th Apr 2015 11:38am |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Chequer / treadplate? Strangely enough I have never had need to walk on any mudflap brackets Steve.
19th Apr 2015 11:42am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2287 |
Hello Balck90
K9F is right drill out carefully. Drill from the rear and use around a 8 mm drill, just get your approach centered as you go, so that you remove equally the rear of the Rivet down to the Spread Washer. I think I sent a small pilot hole down first at around 2-3 mm. We may all do this at some point... The corrosion on the Mudflap Brackets is like watching a time lapse video... Mine where ready for replacement at 3 years old, but I have seen 1 year old Defenders in worse condition here. Refurbishment is an option, and it is not difficult to improve on the painted finish that Land Rover use. Stainless / Aluminium is also worth considering. I made a replacement set up from Stainless Steel, as I had the material with a fold under return edge which I incorporated into the new set, I used a local fabricator with a 5 ton press to give me the main fold, but the shaping and drilling was ok in my workshop. The white layer is Nylon to allows the bottom return edge to work against the Mud Flaps. Again as K9F said Stainless Bolts all round (dome head on the outer brackets), hopefully I will never have to touch these again... Good Luck Click image to enlarge Rear Click image to enlarge Rear inner Click image to enlarge Front Click image to enlarge Front inner Click image to enlarge Rear, the lower edge return and nylon spacer was just to make use of the pre-existing fold in the stainless steel not really necessary, but worked with what I had. SKIP https://www.defender2.net/forum/topic83242.html |
19th Apr 2015 12:17pm |
Did you use the original riv nuts in the rear crossmember to attach the bracket to or have you drilled them out?They look like stainless bolts to me so do you have very long fingers?
19th Apr 2015 4:04pm |
Hello nitram17
Well spotted... ...I tried really hard to get the Mud Flap retaining Bolts out but 3 were showing no signs of moving despite a good soaking (and a wait... ) in PlusGas. All the difficult ones were in the rear cross-member, I got 1 out and sheared 2, one each side. Drilled these out and replaced them with new M6 steel rivnuts. I then worked out that I could just get to all of the locations and thread in a M6 Stainless Steel Bolt from the inside out, locking them off (on the outside) so that my new Brackets would be held in position with M6 SS Nylock Nuts. If you look closly you will see that there is a 5mm Neoprene Gasket between the new Brackets and the Chassis at all locations...this is my OCD kicking in after doing the corrosion prevention thing I wanted to stop water / dirt from getting between the Brackets and the Chassis as much as possible. It was somewhat fiddly the front is much easier than the rear, but it is possible, made life easier as I did this 'preparation' when the defender was up in the air with all wheels off, whilst applying the Dinitrol last year. M6 does feel a bit on the mean side especially as I used M8 elsewhere, you could just drill out the M6 Rivnuts and step up a size, but I went down the route of effectively putting in a locked stud that won't get disturbed now, these were all covered in Dinitrol as the outriggers and rear cross member really did get the treatment, so hopefully that's it now... Click image to enlarge M6 SS Mud Flap Studs Click image to enlarge Replacement Mud Flap Brackets and Gasket to 'cushion' / seal against the chassis SKIP https://www.defender2.net/forum/topic83242.html |
19th Apr 2015 5:53pm |
6.5 mm drill bit worked perfectly for me.
http://www.defender2.net/forum/topic22400....nt+mudflap You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
19th Apr 2015 7:02pm |
Black90 Member Since: 24 Nov 2013 Location: Western isles Posts: 8 |
Many thanks for all your suggestions and help it's very much appreciated I am going to go for stainless and also do the bolt upgrade
21st Apr 2015 1:18pm |
silky16v Member Since: 11 Aug 2014 Location: Cumbria Posts: 99 |
Bosh job done
http://www.gwynlewis4x4.co.uk/product/land...0-rtc4685/ |
21st Apr 2015 1:49pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
I used a 6.7 Drill bit but that's just splitting hairs |
21st Apr 2015 1:53pm |
^^ 6.7mm drill? Thought sizes went by 0.5mm increases, but by 0.1mm? Wow, I don't have that in my toolbox.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
21st Apr 2015 2:35pm |
Wurth sets 1mm in .1 increments to 13mm
really Wurth while investment |
21st Apr 2015 3:05pm |
