Home > Pictures & Video > Croisier Blanch 2010 Pics |
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 |
What size wheels/tyres is that 59-plate 110 DCPU running on?
13th Apr 2010 12:45pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
It has 285-75-16 BFG Muds on Staun 8x16 rims |
13th Apr 2010 2:10pm |
They look superb on her. Is that a size which has a lot of choice in brands/patterns? Mine is coming with stock 235/85r16, I assume with the width of the boost alloys I would not be able to go bigger than i.e. 265/75r16/
Thanks Harvey |
13th Apr 2010 8:33pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
You're not recommended to go past 265 on the 7" Boost rims. Some folks have but you're risking the bead coming off. If you're going up to 285 or beyond, you should go for 8" rims or bead lockers (or both). There are plenty of tyre choices for 285 One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
14th Apr 2010 1:25am |
I guess bead-lockers (asthe name suggests) are a means by which the tyre's bead is mechanically locked to the rim of the tyre. But are they something built into special wheels, or are they something that can be bought and applied to any wheel and tyre?
Is there much difference in fuel consumption going up the tread width? Thanks, Harvey |
14th Apr 2010 7:29am |
bead-lockers are special rims. They are bolted on all the way round (so you need the rim to be drilled for the bolts).
As for fuel consumption: In theory the weight of the vehicle won't change so at a similar pressure, the contact patch of the tyre should be the same (pressure = force x area). If the tyre is wider, the contact area will be shorter. That would mean the same amount of rubber in contact with the road, the same friction and the same mpg. However, I'm sure there'll be other factors (you'll put more force on the tyre when turning so it might take more energy off in the bends; wider tyres tend to be more off-road biased and therefore have more heat loss, friction and a lower mpg...). It's safe to assume that every modification to a LR saps your mpg I installed rubber mats in the footwell and I'm sure it cost me 2mpg One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
14th Apr 2010 8:54am |
See this thread for example bead-lockers
http://www.defender2.net/forum/topic3044.html One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
14th Apr 2010 8:56am |
No need for special wheels i have these fitted in my wheels and they lock both beads unlike most other systems http://www.staunproducts.com/beadlock.php |
14th Apr 2010 11:32am |
Sonic - they look quite effective. What do you do with the valve stem for the bead-locker? Do you have to drill a separate hole in your rims? One that started out as a 2.4 TDCi 110 XS
15th Apr 2010 2:48am |
Hi Alan
I was ok as i have Staun wheels that have the extra hole pre drilled, but to fit them in std rims you would need to drill another hole |
15th Apr 2010 1:48pm |
Makes sense
I'll add it to the list One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
15th Apr 2010 2:26pm |
Buzu06 Member Since: 07 Jul 2009 Location: Bahrija Posts: 16 |
[quote="Sonic3d"]
2 led work lights mounted on the rear facing forward helped with chain fitting in the dark quote] Where can I buy a set of these LEDs? I'm planning to install them as reverse lighting but cant find them online Thanks Gary |
22nd Sep 2010 4:09pm |
Hi Gary
They came from Watts Truck Centre in Gloucester near where i live |
22nd Sep 2010 6:36pm |
Thats why I couldn't find them..
Anyone knows of sources online please? Thanks Gary |
26th Sep 2010 9:11am |
