Home > Tdi > What Engine Colour |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10363 |
I think your attention to detail is making my rebuild look a bit half-assed.
How about keeping it the original colours? |
19th Mar 2015 7:39am |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
The engine i am hopeing to get has been stored under cover but think in a damp atmospher and all the ally stuff has slightly oxidised so thinking if i paint these parts i mite aswell paint the rest of the engine aswell but not all one colour Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
19th Mar 2015 10:10am |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
Duck egg blue!
19th Mar 2015 10:38am |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Have it chemically cleaned then it would look like a brand new engine. Thier is also a shot blaster who uses crushed cherry stones not that far from you. it is located on the small industrail estate near where B&Q stockport is. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
19th Mar 2015 12:36pm |
be honest your always going to have problems getting paint to stay on a engine
get engine as clean as poss ,, good steam clean will do then wash off with thinners ( I wouldn't fancy having it blasted with any kind of grit etc due to it getting inside ) most important thing when painting is a very very thin coat first ( even so thin you can hardly see any colour to it ), the thin coat will soak in to any rust or rough casing areas next coat bit thicker , then next coat thicker if you paint first coat thick it will not last and will look terrible within 6 months even after 2-3 coats you still don't want a thick coating , just light flick over coats and paint while other coats are tacky painted quite a few race engines and its the only way to get it to look good and last as long as poss |
19th Mar 2015 1:34pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
We have a BUPI cleaner in our workshops (like a gigantic dishwasher for engines) if you can get the block to me I'll happily shove it in there for a few hours !. We paint the engines with a paint that is very similar to stove enamel.
19th Mar 2015 8:25pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Exactly what colour I would paint it! A genuine Land Rover engine colour 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
19th Mar 2015 8:32pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Most off the 200 Tdi,s I have seen the engine appears to be a goldy colour, were they that colour when new ? 2005 Td5 90 XS
Steve |
19th Mar 2015 9:16pm |
Yeah i would amagine when i take the block for machining they will clean the block anyway and i can clean everything else but if not i will have to give it a good clean Graham
20th Mar 2015 1:21am |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Put it all together in one piece and spray it all massey ferguson grey machine enamel. Job done. Rhubarb and custard let fly with their secret weapon.
20th Mar 2015 8:10am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Who are you getting the block done by?
I would stick to original gold/brown-orange paint, sound boring but mine still has original paint on it after 24 years so can't be that bad! One route to look at for the ancillary is having them wet blasted. We have a company near us who weirdly make exhausts but they can do wet blasting and the results are amazing. Much easier than all that boring polishing and less damaging. Brings aluminum up like brand new! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
20th Mar 2015 1:41pm |
A company called Princess Engineering in Levenshulme, Manchester, used them for years so has my dad when he was alive aswell as a couple of firms i have worked for over the years aswell Graham
21st Mar 2015 1:10am |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
My ROW defender had a replacement 300tdi engine re manufactured by Land Rover themselves in 2006. It came from the crate resprayed in thick silver paint all over, rocker cover and all. It all flaked off the head and rocker cover within weeks due to no primer used!
1st Apr 2015 4:52am |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
Black in my opinion. Of all the things in the engine bay, the block is not the thing you probably want to accentuate. I think colour works best when used sparingly and in coordination, i.e. silicone hoses, etc.
3rd Apr 2015 12:38pm |
